Honda S2000 Honda S2000
O2 sensor...
Old Jul 5, 2002 | 09:48 PM
DevilS2000F's Avatar
Default O2 sensor...
did anyone remove the Cat from S2K?did anyone figure out how to bypass the O2 sensor so the engine check light won't come up....thanx...
Old Jul 6, 2002 | 11:46 AM
jerrypeterson's Avatar
Default Re: O2 sensor... (DevilS2000F)
At this time there is no workaround other than to replace the ECU. The ECU requires readings from both 02 sensors. The readings are totally off for the 2nd 02 sensor if you remove the Cat. There are no measurable gains from removing the Cat so why even bother?
Redsun
Oct 1, 2004 02:46 PM
IronQQQ
Aug 27, 2003 08:52 AM
intekragsr
Feb 4, 2002 06:35 AM
Etylorcen
Oct 25, 2001 07:31 AM
R134
Aug 27, 2001 02:08 PM
