Honda S2000 Honda S2000
N S X COMPRESSION
Old Mar 26, 2002 | 10:10 AM
MaD3 In JaPaN's Avatar
Default N S X COMPRESSION
just wondering what the compression ratio on stock 97 and up NSX's are?????? any good forged rods out there too?????????
Old Mar 26, 2002 | 10:57 AM
grippgoat's Avatar
Default Re: N S X COMPRESSION (New2HD)
Stock NSX rods are forged titanium. Very light, and I presume strong, but I don't know HOW strong. I'm not sure if FastNSX (500+ whp) is using stock rods on his car or not.
Compression is 10.x:1. Check somewhere like carpoint.com, their specs should have compression ratio (although I've seen them list it incorrectly). Or check Acura's website. The 2002 NSX motor is the same as 97-2001.
-Mike
Old Mar 26, 2002 | 11:00 AM
no2nsx's Avatar
Default Re: N S X COMPRESSION (grippgoat)
compression is 10:2:1 and I belive david does use the stock rods for 508 to the wheels
[Modified by no2nsx, 8:01 PM 3/26/2002]
Old Mar 27, 2002 | 09:14 PM
Default Re: N S X COMPRESSION (no2nsx)
just curious what do the 97 and up NSX's run in quarter miles and 0-60's?????
Old Mar 27, 2002 | 09:25 PM
BoM's Avatar
BoM
like a 13.3
Old Mar 28, 2002 | 08:47 AM
nsxtcjr's Avatar
New User
Default Re: N S X COMPRESSION (BoM)
13.3 for the NSX-T, but the coupe (including the Zanardi) has been tested at 12.9.
Old Mar 28, 2002 | 08:22 PM
Default Re: N S X COMPRESSION (nsxtcjr)
alright i was looking through the car tech and bell tech turbo kits and they said the nsx's from like 91-96 run 1/4 mile in 14.4.........i don't think that's true cuz that seems pretty high righ there, and u guys say the 97 and up Nsx-t's run 13.3's.....ho does that time go down by 1 sec in 20 extra hp's and an extra gear.... also they said these turbo kits, give u about 120 hp's, and people are running only 12.8's in them?????? if u put the bell tech turbo kit in the 97 and up NSX-T's what should they run??????????????????? cuz $9000 is a lot of money to spend on just 12.8's when the zanardi's could hit 12.9's and the japanese 280 hp NSX type S hits it in 12.887 stock.................
Old Mar 28, 2002 | 09:18 PM
nsxtcjr's Avatar
New User
They lie.
3.0-liter 5-speed NSX Coupe
13.7 (Motor Trend 12/90)
13.8 (Car and Driver 9/90)
13.47 (Sports Car International 12/90)
3.0-liter 5-speed NSX-T (heavier than the coupe)
13.7 (Motor Trend 6/95)
13.8 (Road & Track 6/96)
3.2-liter 6-speed NSX-T
13.5 (Road & Track 5/97)
13.3 (Motor Trend 5/97)
3.2-liter 6-speed NSX Zanardi (Coupe)
12.9 (Car and Driver 7/98)
However, if you're concerned about straight line performance and the price of mods and how much you get for what you spend, there are lots better cars to get than an NSX.
Old Mar 29, 2002 | 05:16 AM
Ponyboy's Avatar
Painting Masterpieces
Supra? Mustang? Civic?
Old Mar 29, 2002 | 09:10 AM
alright......so what do u think would the nsx-t 3.2 liter 6 speeds would run with the belltech twin turbo system???????if it supposedly gives it 120 hp's to the crank.
Old Mar 29, 2002 | 11:14 AM
HondasRfast's Avatar
From: Alexandria, Louisiana, United States of Arabia
Default Re: N S X COMPRESSION (Ponyboy)
Mustang GT should be mid-high 13s, Supra should b about the same, and an Si should be low-mid 15s.
Old Mar 29, 2002 | 11:30 AM
no2nsx's Avatar
mark has a 97 bell and he ran 12.04 @ 118.4 @ 8psi on pump gas and street tires...
Old Mar 31, 2002 | 10:03 AM
so do u guys think that 10g turbo kit for the nsx is worth it??????
Old Apr 2, 2002 | 08:51 AM
PhatLewt's Avatar
Based on the questions you're asking, I would say for you: No.
The NSX is not about drag racing, it's worthless until you get into the power band in second gear. And then it's an insane thrill ride that many cars try to immitate. The NSX is not design to launch smoothly off the line from a dead start.
It's designed to power out of a tight turn in second gear at the base of the power band and carry it for an insane amount of time at 1.1 G's on race tires.
If you want to drag race, go buy a new Cobra R Mustang with 390 hp and have fun with it. If you want to track race, the NSX deserves a lot of consideration if you have the desire to own something special.
Old Apr 4, 2002 | 02:32 AM
Art Vandeleigh's Avatar
Default Re: N S X COMPRESSION (PhatLewt)
Old Apr 4, 2002 | 09:17 AM
Ponyboy's Avatar
Preach it brother man.
Old Apr 6, 2002 | 09:52 PM
Maximus's Avatar
Does anyone have any stats or info on the Gruppe M supercharger kit for the NSX? Go to http://www.takakaira.com to see the kit.
Preludepradit
Mar 1, 2007 04:39 PM
lavo81
May 8, 2005 03:48 PM
dirtyturtle
15
Jun 30, 2004 10:19 AM
