Honda S2000 Honda S2000
increase tq?
Old Jun 4, 2006 | 09:59 PM
Ricky26500's Avatar
Default increase tq?
Hey everyone...bout a couple nights ago I went to the track I just got MY06..hehe..and I raced this Cobalt SS like 5 times and we were neck and neck the whole time..im assuming he kept up with me because of his torque?!..now I understand that the cobalt is 205hp supercharged and the torque is around the same range...is there any way to increase the torque in our cars??..and still keep it N/A?..or is turbo/supercharger the way to go?..I would really like to stay N/A tho..any suggestions would help..
One more question..this drive-by-wire throttle system...what is exactly is that?..I've heard that previous models didnt have this but now the '06 models do...can anyone explain to me what the heck that is??...does it affect the shifting at all as far as acceleration???...sry for being such a freakin noob..but I had to ask right?...
thanks in advance guys!!
Old Jun 5, 2006 | 12:17 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: increase tq? (Ricky26500)
Get a new final drive gear. That will increase torque at the wheels.
Drive by wire does not affect shifting. The clutch delay does, however.
Old Jun 5, 2006 | 04:34 AM
papa5murf's Avatar
think you need to learn/practice how to drive the S... the colbalt should not be keeping up with you..
Old Jun 5, 2006 | 04:35 AM
papa5murf's Avatar
Default Re: increase tq? (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Get a new final drive gear. That will increase torque at the wheels.
not on a dyno.... it doesn't really "give" you more power/torque..
Old Jun 5, 2006 | 04:56 AM
JDM knowledge's Avatar
Default Re: increase tq? (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">think you need to learn/practice how to drive the S... the colbalt should not be keeping up with you..</TD></TR></TABLE>
lol. yeah for real buddy.
Drive-by-wire is a system that controls your throttle input via a computer. Usually you have a throttle cable and you control how much throttle you want. Now with your model it decides for you, mainly for the traction control. There is also a slight delay when you press the gas, usually. I dont know how well the Honda one is but in other cars its pretty apparent and annoying.
Old Jun 5, 2006 | 09:34 AM
mykcuz's Avatar
Default Re: increase tq? (JDM knowledge)
just got an 06 and u lost the warranty already...hope u arent paying for it
u could have a speed shop mod the ecu, cold air intake, exhaust, stickers, the final drive gear will make your trq more usuable for the track, bring a gas tank to the track with you and only put enough gas in for each race, saving weight, liquid is one of the heaviest things u can remove. you can put in a lightweight driveshaft, replace to a lightweight flywheel, and the smartest way to improve track times is to improve the driver
Modified by mykcuz at 10:45 AM 6/5/2006
and the track should match u up with a car thats gonna be a close race
Modified by mykcuz at 10:46 AM 6/5/2006
Old Jun 5, 2006 | 11:43 AM
* B A N N E D *
not on a dyno.... it doesn't really "give" you more power/torque..</TD></TR></TABLE>
Shorter gear ratio = higher torque ratio. Cmon now, it's like using 2nd gear instead of 3rd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">
Drive-by-wire is a system that controls your throttle input via a computer. Usually you have a throttle cable and you control how much throttle you want. Now with your model it decides for you, mainly for the traction control. There is also a slight delay when you press the gas, usually. I dont know how well the Honda one is but in other cars its pretty apparent and annoying. </TD></TR></TABLE>
I've driven 2 06's, the delay isnt even noticeable, but the VSA is.
Old Jun 6, 2006 | 05:58 AM
I've driven 2 06's, the delay isnt even noticeable, but the VSA is.</TD></TR></TABLE>
i'd like t oadd i saw a guy at a recent auto-X spin out in a 06. I really hope he had turned it off cause to spin out even with something assisting you is kinda embarassing. In his defense he was pushing it pretty hard.
Old Jun 6, 2006 | 08:39 AM
* B A N N E D *
i'd like t oadd i saw a guy at a recent auto-X spin out in a 06. I really hope he had turned it off cause to spin out even with something assisting you is kinda embarassing. In his defense he was pushing it pretty hard. </TD></TR></TABLE>
I threw an 06 into an onramp with the VSA on, and it corrects understeer noticeably, but I haven't had a chance to test the oversteer correction.
Old Jun 6, 2006 | 09:42 AM
ap1_s2k's Avatar
I think a cobalt shouldn't be next to u at all!! If it was then, what was your time ?What i heard is the 06 can run high 13's bold stock !!! You might need to check your driving skills not to be mean or anything!!
Old Jun 6, 2006 | 10:55 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: increase tq? (ap1_s2k)
like its been said gears and practice driving... ill be damned if a "shitbolt" takes me out !
Old Jun 6, 2006 | 01:50 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1_s2k &raquo;</TD></TR><TR><TD CLASS="quote">I think a cobalt shouldn't be next to u at all!! If it was then, what was your time ?What i heard is the 06 can run high 13's bold stock !!! You might need to check your driving skills not to be mean or anything!!</TD></TR></TABLE>
not just the 06, all S2000's in stock form are capable of 13's. It takes a very good driver to do it (also weather, elevation, temp, etc... play a factor)
Old Jun 6, 2006 | 04:06 PM
Nighthawk R18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mykcuz &raquo;</TD></TR><TR><TD CLASS="quote">just got an 06 and u lost the warranty already...hope u arent paying for it
Modified by mykcuz at 10:46 AM 6/5/2006</TD></TR></TABLE>
Excelent advise
*gets notebook*
Old Jun 6, 2006 | 06:21 PM
Ricky26500's Avatar
well i dont really race...sry if my "driving skills" suck..lol..I thought he wasnt gonna keep up either but somehow he did...i was disappointed but whatever...when should I shift??..any suggestions..idk much about racing...
Old Jun 6, 2006 | 08:23 PM
Sideways's Avatar
Default Re: (Ricky26500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricky26500 &raquo;</TD></TR><TR><TD CLASS="quote">well i dont really race...sry if my "driving skills" suck..lol..I thought he wasnt gonna keep up either but somehow he did...i was disappointed but whatever...when should I shift??..any suggestions..idk much about racing...</TD></TR></TABLE>
Shift just before the rev limiter. Anything less and your rpms in the next gear are too low. The tach should be blinking.
Old Jun 6, 2006 | 08:42 PM
LAS2K's Avatar
Default Re: (Sideways)
what rpm do you suggest launching at....an ap1 for example.
Old Jun 7, 2006 | 04:36 AM
mykcuz's Avatar
the s2k isnt set up stock to drag, sure a good driver can get good results, but your average driver fooling around at the track is gonna run up against someone like this supercharged cobalt that can probably make some better launch times and hang in there.
the s only finishes the 1/4mile at 98mph i think, so the ss could be a little slower and still seem close at that speed.
Old Jun 7, 2006 | 07:40 AM
noturtypicalone's Avatar
you should be launching at around 5800-6000. drop the clutch and keep the throttle floored. shift right when the tach blinks, and shift fast.
Old Jun 7, 2006 | 07:43 AM
Nishant's Avatar
Default Re: (noturtypicalone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noturtypicalone &raquo;</TD></TR><TR><TD CLASS="quote">you should be launching at around 5800-6000. drop the clutch and keep the throttle floored. shift right when the tach blinks, and shift fast.</TD></TR></TABLE>
shift when the tach blinks? meaning after it hits the rev limiter, you nuts!
Old Jun 7, 2006 | 07:56 AM
Default Re: (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">shift when the tach blinks? meaning after it hits the rev limiter, you nuts! </TD></TR></TABLE>
no you keep going...you will here a noise but that is just your 2nd VTAK kicking in.
Old Jun 7, 2006 | 08:46 AM
not sure about an ap1. ..but on an ap2, the tach blinks before the rev-limiter. tach blinks at 8000, limit is 8200
so yea..shift when the tach blinks, instant shift light
Old Jun 7, 2006 | 08:48 AM
LBBP R's Avatar
Default Re: (JDM knowledge)
only way to increase tq... would be..
increase bore diameter
increase stroke
get feel's 2.3L kit
Old Jun 7, 2006 | 09:25 AM
SilverDc2's Avatar
Default Re: (LBBP R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LBBP R &raquo;</TD></TR><TR><TD CLASS="quote">only way to increase tq... would be..
increase bore diameter increase stroke
get feel's 2.3L kit </TD></TR></TABLE>
i think it would be a waste of money and time to incease displacement by .1 2.2-2.3 isn't going to be that noticeable,
get a 2.5 stroker kit. or Turbo that bish
zacarroll
K Series
May 10, 2013 07:18 AM
wc4ohio
Apr 21, 2011 10:58 AM
kawaboy14
Honda S2000
30
Aug 15, 2007 01:18 AM
dhdatnigga
Jun 26, 2006 12:48 PM
