Honda S2000 Honda S2000
idling not properly when start the engine
Old Jan 1, 2005 | 06:50 PM
SpoonTypeR's Avatar
Default idling not properly when start the engine
i bought a used s2000
and its got few mod in it
its got Mugen Header,ARC exhaust
but i duuno if the guy change the ECU or not or CAM
heres the problem,every time when i start the engine,the RPM seems like drop a lot and almost stall the car and goes back up again
what kinda problem could it be?and is that normal?thanks
Old Jan 1, 2005 | 06:52 PM
Nishant's Avatar
Default Re: idling not properly when start the engine (SpoonTypeR)
try resetting the ECU but what rpm's is it dropping to? like whats the lowest it drops to and then when it fluctuate
Old Jan 1, 2005 | 10:52 PM
SpoonTypeR's Avatar
Default Re: idling not properly when start the engine (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">try resetting the ECU but what rpm's is it dropping to? like whats the lowest it drops to and then when it fluctuate</TD></TR></TABLE>
hm...the rpm drops to like 200-300 i think
u can feel the car shaking like almost stalling
how do i reset the ecu?
Old Jan 2, 2005 | 07:58 AM
papa5murf's Avatar
that also happens to me once in a while.. can't figure it out...
Old Jan 2, 2005 | 11:00 AM
92jdmhatch's Avatar
Default Re: idling not properly when start the engine (03s2kblue)
happens to me too...once in awhile it just decides to do that...
Old Jan 2, 2005 | 07:52 PM
SpoonTypeR's Avatar
Default Re: idling not properly when start the engine (92jdmhatch)
so thats normal?or should i be worry?
Old Jan 2, 2005 | 07:56 PM
papa5murf's Avatar
i think it's normal if it happens once in a while.. i've noticed it seems to happen when the weather is very cold out.....
Old Jan 2, 2005 | 08:00 PM
wannas2k's Avatar
im not sure does it set a check engine lite?
Old Jan 2, 2005 | 08:39 PM
SpoonTypeR's Avatar
Default Re: idling not properly when start the engine (wannas2k)
my check engine light already comes on.becuz i have no cat
Old Jan 2, 2005 | 11:08 PM
windchaser's Avatar
you can wack the map sensor a little see if it helps.....
Old Jan 3, 2005 | 10:44 AM
92jdmhatch's Avatar
Default Re: idling not properly when start the engine (windchaser)
mine happens when its warm weather...
Old Jan 3, 2005 | 07:48 PM
SpoonTypeR's Avatar
so that's normal for s2000 right?
or should i reset my ECU?
and how do i reset the ECU?
Old Jan 3, 2005 | 08:05 PM
9kFever's Avatar
pull the fuse or disconnect the battery for 15 secs, you will need you radio code though....
Old Jan 6, 2005 | 12:50 PM
SecretAsianManJV's Avatar
That's what happened to mine a month ago. It's in the shop and we're still trying to figure out the cause. So far we've checked the IAC, mostly all of the sensors, checked if there was a vacuum leak, etc. The only thing I can think about is probably a bad ecu or the TPS sensor. I'm through with fiddling around with it so I just sent it to a local honda dealer to see if they can figure out it. Hopefully they can because I can't stand not having my s2000 anymore.
v8killaz
Honda Civic (2001 - 2005)
13
Sep 11, 2008 03:33 PM
turboteg90
Jun 24, 2008 11:52 PM
Berlinetta F1
Sep 9, 2007 10:08 AM
98B18C1
Dec 7, 2006 12:02 AM
riceball777
Jun 4, 2003 09:46 AM
