Honda S2000 Honda S2000
Espelir Spring Installation
Old Mar 31, 2007 | 10:57 AM
NPizano2000's Avatar
Default Espelir Spring Installation
Ive got espelir springs and my back is sagging a decent amount. Im wondering if its possible that the shop that put em in could of possibly put em in backwards??? Ive heard of this...
Old Mar 31, 2007 | 04:07 PM
327da9's Avatar
Default Re: Espelir Spring Installation (NPizano2000)
Take the body out of your trunk
Old Mar 31, 2007 | 08:31 PM
Otherguy's Avatar
NASIOC.com
Default Re: Espelir Spring Installation (327da9)
Well the springs in the rear are going to drop the rear 1.5 inches, and the front 1.3... They prob just need to settle
Old Mar 31, 2007 | 09:34 PM
JDM_KP's Avatar
I put in rsr springs and had the same problem. Them I put in my eibachs, problem solved and it rode 837573484758348 times better. Next I'm putting in ground control because I cant spend $1k on suspension yet...
Old Apr 1, 2007 | 01:43 AM
rusted_nailz's Avatar
alot of people who install springs on the s2k forget to preload the suspension before they tighten all the bolt. If they forgot this the front upper control arms are binding so thats why the fronts sit higher than the rears. I had the same issue like you on the same springs. I just raised the car, loosened all the bolts, preloaded the suspension and retighten them. Solved the problem, the car sits even now.
Old Apr 1, 2007 | 12:56 PM
Default Re: (rusted_nailz)
forgive me but how do you preload the suspension? By compressing the spring??
Old Apr 1, 2007 | 04:24 PM
jeremyvr6's Avatar
Default Re: (NPizano2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NPizano2000 &raquo;</TD></TR><TR><TD CLASS="quote">forgive me but how do you preload the suspension? By compressing the spring??</TD></TR></TABLE>
loosten the upper contrl arm bolts and jack up the suspension to compress everything and then re-tighten them
Old Apr 2, 2007 | 12:49 PM
yea jack each side of the suspension on the lower ball joint. Its on the bottom part of the suspension behind the rotor. make sure all the bolts are loose before you do it.
Old Apr 2, 2007 | 01:09 PM
the soL that could's Avatar
from what i understand, you do not need to preload springs...only coilovers. that actually might be the problem; that they are preloaded.
i believe you springs are backwards... but i'm not 100% certain.
Old Apr 2, 2007 | 01:14 PM
the spring is not the issue, the issue is that when installing springs on a s2k requires you to undo the front upper control arms. The arms have bushings, if you tighten all the bolts before preloading the bushings will bind and not allow the suspension to travel correctly. That is why his car is sitting uneven... I know this first hand because I had the same problem...
AznBlueBoy
Suspension & Brakes
11
Aug 4, 2011 12:05 AM
Makavelidadawn
Honda Civic (2006 - 2015)
Mar 21, 2010 11:13 PM
DarkBB4
Apr 8, 2006 03:19 PM
sickofitall1113
Jul 6, 2005 12:50 PM
mamaboy
Nov 2, 2001 06:37 PM
