Ground Control Helper Spring
Old Nov 2, 2001 | 06:00 PM
mamaboy's Avatar
Default Ground Control Helper Spring
I have a set of Ground Controls on my TEG
i've seen the eibach ers helper springs on a image somewhere on the internet...
but i was wondering what they were for....daily driving...autocrossing....
what???
cause if it's gonna help my suspension...then it's an investment i'd take....
what are they? and what is it's purpose? and is it used with the ground control coilover system?
Old Nov 2, 2001 | 06:37 PM
Scorpaznatica's Avatar
New User
Default Re: Ground Control Helper Spring (mamaboy)
Helper springs are for comfort only, their purpose is too keep the main springs from rattling around. It's a common side effect to coilover suspension with short main springs, the helper spring will fill the "empty" space, for a lack of better terms. They're usualy very thin and will compress all the way when there is load on the suspension. The pic below are tender springs off a Tein coilover.
Tender springs is what you'd probably want instead. Basically they're shorter & less stiff than the Main springs. Using these will allow you to have variable spring rates. The lower spring rate (from the tender springs) will provide comfort during daily driving situation. While the stiffer rate will take over once the tender springs are fully compressed and the Main springs take over, such is the case when you're on the racetrack taking a decreasing radius turn...which will compress your outer suspension enough so that the Main (higher) spring rates are the ones being used.
HTH
vinuneuro
Suspension & Brakes
Oct 17, 2007 11:25 AM
E-AT_me
35
Jan 11, 2005 08:31 PM
rambyCAMRY
Apr 6, 2004 10:51 PM
garados
Feb 5, 2002 02:41 PM
jonsteR
27
Jan 4, 2002 11:45 AM
