Honda S2000 Honda S2000
ES Oval on a S2K
Old Feb 14, 2007 | 10:23 AM
Suzukablue's Avatar
Default ES Oval on a S2K
Will this work? I'm thinking of buying 2 ovals are replacement for my stock exhaust and then weld the tip. I just want some good sound but dont have the funds right now for a pricey exhaust.
Old Feb 14, 2007 | 11:51 AM
tmkpres's Avatar
Default Re: ES Oval on a S2K (Suzukablue)
arn't the outlet only 2.25 ?? I love those mufflers back in the day like in 98-99
Old Feb 14, 2007 | 12:12 PM
Suzukablue's Avatar
Default Re: ES Oval on a S2K (tmkpres)
yeah i still love them until now. there's a 2.5 inlet version
Old Feb 14, 2007 | 01:05 PM
Suzukablue's Avatar
anybody else that confirm its gonna work?
Old Feb 14, 2007 | 04:05 PM
Mr. Projekt's Avatar
* B A N N E D *
If you're going to use stock piping, you need a 2" inlet muffler unless you want to weld in some 2"-2.5" expanders.
Old Feb 14, 2007 | 08:09 PM
Suzukablue's Avatar
Default Re: ES Oval on a S2K (Mr. Projekt)
would you guys recommend doing the ES oval stock piping route or just save money on a cat back for $600 and up?
Old Feb 14, 2007 | 10:19 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suzukablue &raquo;</TD></TR><TR><TD CLASS="quote">would you guys recommend doing the ES oval stock piping route or just save money on a cat back for $600 and up?</TD></TR></TABLE>
depends, if all you want is more noise then es oval is great, consider you a str8 thru replaceing a twin loop muffler.
600+? what kind of catback you have in mind?
Old Feb 15, 2007 | 07:15 AM
Suzukablue's Avatar
Default Re: ES Oval on a S2K (iam7head)
invidia titanium tip is $580. so far its the cheapest i found. i guess i'm just more concerned about the sound rather than HP gains
Old Feb 15, 2007 | 08:16 AM
silentdancer's Avatar
invidia is extremly loud, i would take OEM over the invidia
Old Feb 15, 2007 | 09:27 AM
Suzukablue's Avatar
Default Re: ES Oval on a S2K (silentdancer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdancer &raquo;</TD></TR><TR><TD CLASS="quote">invidia is extremly loud, i would take OEM over the invidia</TD></TR></TABLE>
yeah that was what i heard about it. whats your opinion about putting 2 ES ovals instead and use stock piping?
Old Feb 15, 2007 | 09:38 AM
* B A N N E D *
2 ES ovals and use stock piping</TD></TR></TABLE>
Old Feb 15, 2007 | 01:59 PM
import2nr88's Avatar
two es mufflers in 2.25 on the stock piping should be nice sounding and you might see small gains as you are going from a baffled muffler to a straight throught design.
Old Feb 15, 2007 | 02:38 PM
Suzukablue's Avatar
Default Re: (import2nr88)
thanks for the input. i might just go with this route for now.
Old Feb 15, 2007 | 03:20 PM
jerk's Avatar
Banned
go single. used apexi n1 full catback goes for 3-400 used.
Old Feb 15, 2007 | 03:21 PM
Infinity_Racer's Avatar
Default Re: (Suzukablue)
like everyone else said it would work fine...
people have been replacing the stock mufflers with the "shinier" magnaflows without any problems...try adding a TP and it will probably sound nicer
Old Feb 15, 2007 | 10:13 PM
kingSfit's Avatar
dont forget to record a clip
91integraLSVTEC
May 21, 2005 09:00 PM
TegoDC5
14
Apr 11, 2005 05:48 PM
al3e
Nov 21, 2004 08:10 AM
jdmjeff
Nov 15, 2004 08:46 PM
newBcrxer
Apr 29, 2004 09:10 PM
