Brake Light Stays on?
Old 03-16-2012, 09:57 AM
ElCivic89's Avatar
Icon6 Brake Light on Dash Board Stays on?
After realising my hand brake to drive my brake light on my dash board stayes on i have an 89 Si is it time for rear brakes?
Old 03-16-2012, 10:36 AM
1991civiclx13's Avatar
Default Re: Brake Light Stays on?
If you mean your brake lights this should help
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/brake-lights-stay-how-i-fixed-them-2254546/
Old 03-16-2012, 10:58 AM
rustbucketrex's Avatar
Check your brake fluid level.
Old 03-16-2012, 11:19 AM
Keyboard Humorist
4drEF's Avatar
... but do NOT add fluid.
Brake fluid is the one fluid that you never top off for maintenance.
The brake reservoir cap has a sensor (a float) in it that is designed to trigger your brake light on your cluster when you have low fluid.
Obviously a leaking tube will cause a low fluid condition.
However if everything is working properly (no leaks) the brake light means your pads/shoes/rotors/drums have worn significantly.
The caliper pistons will be extended more than normal to reach the worn pads so more fluid will be stored in the caliper housing rather than in the reservoir.
When you replace the worn components, then it is time to add new fluid and perform a flush..
Old 03-16-2012, 12:48 PM
Tyson's Avatar
x2.
he said dash light.
Old 03-16-2012, 01:54 PM
sorry, did'nt see that for some reason
jjr_99prelude
08-31-2007 09:23 PM
eluded
05-27-2006 10:35 AM
Ha7chB4cK
05-03-2005 06:06 PM
itr_dc2
07-12-2004 10:22 AM
type r 01-1063
04-03-2003 11:04 PM
Quick Reply: Brake Light Stays on?
