Honda S2000 Honda S2000
Door Speakers
Old 11-30-2007, 10:29 AM
wrice4's Avatar
Default Door Speakers
Hey guys... what size are the door speakers in the 2003 s2k. I have some 6" focals but i think those are too big...?
Old 11-30-2007, 12:46 PM
ReddotsS2K's Avatar
Default Re: Door Speakers (wrice4)
if i remember correctly its 6.5
try google
Old 11-30-2007, 05:05 PM
-iLLuZioN-B18C1's Avatar
Default Re: Door Speakers (ReddotsS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">if i remember correctly its 6.5
try google </TD></TR></TABLE>
6.5, but double check the depth, the depth of the 6.5" is what usually limits you.
Old 12-01-2007, 06:48 PM
wrice4's Avatar
ok the focals are 6.5, do i need anything else or just plug n play...
Old 12-01-2007, 10:15 PM
ReddotsS2K's Avatar
Default Re: (wrice4)
yeah, change the connectors on the end. honda has some pecial ones on there. i just cut the wire, stripped it, and found some connector things laying around.
also be careful when you remove the door panel, i believe there is 2 screws in the door handle and one in the door opener thing.
i remember there being something else to, like the stock speakers are only held in by 3 instead of 4 screws. not sure though...might of been my bimmer.
Old 12-02-2007, 12:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 &raquo;</TD></TR><TR><TD CLASS="quote">ok the focals are 6.5, do i need anything else or just plug n play...</TD></TR></TABLE>
check the depth of the speakers if you want a direct drop in speaker...otherwise you will have to cut the bracket.
max depth
68 mm (2.68") on the top and 79 mm (3.11") on the bottom
Old 12-02-2007, 01:09 PM
purehonda's Avatar
Default Re: (-iLLuZioN-B18C1)
I need new door speakers too. Glad I found this
Old 12-02-2007, 06:23 PM
* B A N N E D *
Right Tighty's Avatar
just keep them small
Old 12-02-2007, 07:41 PM
revhi's Avatar
6.5 is the right side, but you need to make baffles/spacers. Cutting the factory basket is ghetto.
Old 12-03-2007, 04:52 AM
S2KILLA's Avatar
Location: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">6.5 is the right side, but you need to make baffles/spacers. Cutting the factory basket is ghetto.</TD></TR></TABLE>
it may be ghetto but it works. Most aftermarket speakers are going to be too deep for the basket, so cutting them is cheap and effective...
Old 12-03-2007, 09:59 AM
M.A.R.C.'s Avatar
Default Re: (S2KILLA)
i just installed some pioneers in my ap2 this weekend. fit fine.
Old 12-04-2007, 10:03 AM
wrice4's Avatar
so i just need to buy some connecters...?
Old 12-04-2007, 10:58 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 &raquo;</TD></TR><TR><TD CLASS="quote">so i just need to buy some connecters...?</TD></TR></TABLE>
no you can just splice your new speakers with your existing speaker wire... its really an easy install... will take you 20 mins max on each door... PM me if you need more help
Old 12-04-2007, 05:35 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">
no you can just splice your new speakers with your existing speaker wire... its really an easy install... will take you 20 mins max on each door... PM me if you need more help</TD></TR></TABLE>
you don't even have to do that... i just removed the oem plastic connector housing from the wiring and inside are connectors that fit most aftermarket speaker prongs. the only thing i did was dab a little drop of solder on one of the replacement speaker prongs cause it's slightly narrower... i could have just crimped it on a little tighter with pliers or something though. i did it this way so if i ever wanted to put the stockers back in, i could just put the little plastic plugs back on and voila.
Old 12-04-2007, 07:31 PM
wrice4's Avatar
k thanks alot guys
Old 12-06-2007, 11:16 AM
wrice4's Avatar
Ya i just got my Focal door speakers, they are Focal Access 1 165 CA1 68mm dept from wall.....you guys have any opinion on focals or this kind of focal. I have never used them.
Old 12-06-2007, 11:31 AM
ReddotsS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 &raquo;</TD></TR><TR><TD CLASS="quote">Ya i just got my Focal door speakers, they are Focal Access 1 165 CA1 68mm dept from wall.....you guys have any opinion on focals or this kind of focal. I have never used them.</TD></TR></TABLE>
just throw them in man and post the results. im sure they will sound better than stock. it only takes minutes to swap them too.
Old 12-06-2007, 11:38 AM
TheDancingPill's Avatar
Default Re: (ReddotsS2K)
just throw them in man and post the results. im sure they will sound better than stock. it only takes minutes to swap them too.</TD></TR></TABLE>
throw them in
Old 12-06-2007, 11:39 AM
TL1000R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 &raquo;</TD></TR><TR><TD CLASS="quote">Ya i just got my Focal door speakers, they are Focal Access 1 165 CA1 68mm dept from wall.....you guys have any opinion on focals or this kind of focal. I have never used them.</TD></TR></TABLE>You won't be disappointed, Focal makes a great speaker.
Old 12-06-2007, 08:42 PM
wrice4's Avatar
ok cool
SCIVIC94
Audio / Security / Video
03-20-2007 10:24 PM
SheHateMe
11-03-2006 07:56 AM
93gsrhatchbrid
04-02-2006 01:52 PM
kysard
03-07-2004 01:26 PM
lude97dude
01-17-2004 08:23 AM
Quick Reply: Door Speakers
