Door Speakers
Hey guys... what size are the door speakers in the 2003 s2k. I have some 6" focals but i think those are too big...?
Re: Door Speakers (wrice4)
Re: Door Speakers (ReddotsS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K »</TD></TR><TR><TD CLASS="quote">if i remember correctly its 6.5
try google https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> 6.5, but double check the depth, the depth of the 6.5" is what usually limits you. |
ok the focals are 6.5, do i need anything else or just plug n play...
Re: (wrice4)
yeah, change the connectors on the end. honda has some pecial ones on there. i just cut the wire, stripped it, and found some connector things laying around.
also be careful when you remove the door panel, i believe there is 2 screws in the door handle and one in the door opener thing. i remember there being something else to, like the stock speakers are only held in by 3 instead of 4 screws. not sure though...might of been my bimmer. |
Re: (wrice4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 »</TD></TR><TR><TD CLASS="quote">ok the focals are 6.5, do i need anything else or just plug n play...</TD></TR></TABLE>
check the depth of the speakers if you want a direct drop in speaker...otherwise you will have to cut the bracket. max depth 68 mm (2.68") on the top and 79 mm (3.11") on the bottom |
Re: (-iLLuZioN-B18C1)
I need new door speakers too. Glad I found this
just keep them small
6.5 is the right side, but you need to make baffles/spacers. Cutting the factory basket is ghetto.
Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">6.5 is the right side, but you need to make baffles/spacers. Cutting the factory basket is ghetto.</TD></TR></TABLE>
it may be ghetto but it works. Most aftermarket speakers are going to be too deep for the basket, so cutting them is cheap and effective... |
Re: (S2KILLA)
i just installed some pioneers in my ap2 this weekend. fit fine.
so i just need to buy some connecters...?
Re: (wrice4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 »</TD></TR><TR><TD CLASS="quote">so i just need to buy some connecters...?</TD></TR></TABLE>
no you can just splice your new speakers with your existing speaker wire... its really an easy install... will take you 20 mins max on each door... PM me if you need more help |
Re: (S2KILLA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA »</TD></TR><TR><TD CLASS="quote">
no you can just splice your new speakers with your existing speaker wire... its really an easy install... will take you 20 mins max on each door... PM me if you need more help</TD></TR></TABLE> you don't even have to do that... i just removed the oem plastic connector housing from the wiring and inside are connectors that fit most aftermarket speaker prongs. the only thing i did was dab a little drop of solder on one of the replacement speaker prongs cause it's slightly narrower... i could have just crimped it on a little tighter with pliers or something though. i did it this way so if i ever wanted to put the stockers back in, i could just put the little plastic plugs back on and voila. |
k thanks alot guys
Ya i just got my Focal door speakers, they are Focal Access 1 165 CA1 68mm dept from wall.....you guys have any opinion on focals or this kind of focal. I have never used them.
Re: (wrice4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 »</TD></TR><TR><TD CLASS="quote">Ya i just got my Focal door speakers, they are Focal Access 1 165 CA1 68mm dept from wall.....you guys have any opinion on focals or this kind of focal. I have never used them.</TD></TR></TABLE>
just throw them in man and post the results. im sure they will sound better than stock. it only takes minutes to swap them too. |
Re: (ReddotsS2K)
just throw them in man and post the results. im sure they will sound better than stock. it only takes minutes to swap them too.</TD></TR></TABLE> throw them in https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (wrice4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 »</TD></TR><TR><TD CLASS="quote">Ya i just got my Focal door speakers, they are Focal Access 1 165 CA1 68mm dept from wall.....you guys have any opinion on focals or this kind of focal. I have never used them.</TD></TR></TABLE>You won't be disappointed, Focal makes a great speaker.
ok cool
