Honda S2000 Honda S2000
Differential
Old Oct 14, 2008 | 02:59 PM
wjkj08's Avatar
Default Differential
Just wondering if anyone new what other rear ends you can put on the S or whats the best upgrade? I used to have a 240sx with the r33 skyline vlsd and it made the world of difference. Being that its a 5 lug, wondering if you could match that up in an S. Would you have to use the guts out of it and fit it in the stock housing, switch axles, etc.... Not sure about everyone else's, but lately mine kind of clicks under a pressure, like just going up an incline.
Also, doesnt have to do with the diff, but lately when i let off the clutch real slow and go to take off, the car kinda of like chugs, its hard to explain better to see in person. It like cuts in and out until it gets in higher rpm, some people told me flywheel. Don't know to much about the internal stuff so any help would be great......
Old Oct 14, 2008 | 04:02 PM
ReddotsS2K's Avatar
Default Re: Differential (wjkj08)
there is a kit that allows you to put the r200 diff in the s2000, but none other that i know of.
http://www.inlinepro.com/
Old Oct 14, 2008 | 06:05 PM
Black S2K's Avatar
My diff clicks too its been doing that since I have owned the car 25k later I still have no problems with it so don't worry to much about ur diff unless u launch ur car/shift hard as [freak].
Old Oct 14, 2008 | 07:14 PM
ReddotsS2K's Avatar
Default Re: (Black S2K)
im willing to bet that it is not your diff...
you know how many diffs i have been through and it still clicks...which leads be to believe it's axles.
Old Oct 14, 2008 | 08:42 PM
Black S2K's Avatar
Default Re: (ReddotsS2K)
^ i was thinking that two. cause my driver side axel doese click when i make a hard right hand turn. But i was refering to the op's clicking when ur engagin the clutch it kinda sounds like the diff but i guess well never know if its axels or diff.
Old Oct 15, 2008 | 03:42 AM
Under_Pressure's Avatar
Take out the spindle nut, grease it, then re-torque it to 220lb-ft. problem solved
Old Oct 15, 2008 | 04:45 AM
DO_ITR_YoungD_19's Avatar
Axels click. I had that problem once. Got new axels no more clicking.
Old Oct 15, 2008 | 05:05 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Differential (ReddotsS2K)
I have no clicking, I agree that it's probably the axles not the diff making that noise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wjkj08 &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if anyone new what other rear ends you can put on the S or whats the best upgrade? I used to have a 240sx with the r33 skyline vlsd and it made the world of difference. Being that its a 5 lug, wondering if you could match that up in an S.</TD></TR></TABLE>
As stated inline pro makes a kit that allows the use of the R200 Nissan differential. It includes a new drive shaft, axles, hubs, studs and mount.
Old Oct 15, 2008 | 05:30 AM
What Honda should do is make a stronger diff. I broke mines and my only mods are a exhaust and drop in filter. Driver error and abuse could have alot to do with it, but my boy beats on his 240 all the time day in and day out with no issues yet lol. But im gonna look into the r200 diff kit.
Old Oct 15, 2008 | 03:44 PM
wjkj08's Avatar
Any ideas on what i mentioned on the clutch issues? Air in the lines? It doesnt slip because ive done the "tests" to check that
Old Oct 16, 2008 | 05:15 PM
pli's Avatar
pli
Default Re: (wjkj08)
for sure, clicking is from axle. i had one break on me before. and i know its not a diff, because i broke one of those two.
i also have a question about the diff:
1. say my diff is whining right now...will it have a chance of breaking on me if i drove it hard? not shifting hard...but like going at high RPMs?
Old Oct 16, 2008 | 05:43 PM
Agent Zero's Avatar
Default Re: (pli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pli &raquo;</TD></TR><TR><TD CLASS="quote">
change diff. fluid maybe?
Old Oct 17, 2008 | 09:33 AM
ReddotsS2K's Avatar
Default Re: (pli)
If your diff is whining, chances are that you have sheered off a couple teeth somehow. I would Replace the fluid and check for metal shaving when you drain it.
Old Oct 17, 2008 | 11:39 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wjkj08 &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if anyone new what other rear ends you can put on the S or whats the best upgrade? I used to have a 240sx with the r33 skyline vlsd and it made the world of difference. Being that its a 5 lug, wondering if you could match that up in an S. Would you have to use the guts out of it and fit it in the stock housing, switch axles, etc.... Not sure about everyone else's, but lately mine kind of clicks under a pressure, like just going up an incline.
axle nut TSB: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under_Pressure &raquo;</TD></TR><TR><TD CLASS="quote">Take out the spindle nut, grease it, then re-torque it to 220lb-ft. problem solved</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wjkj08 &raquo;</TD></TR><TR><TD CLASS="quote">Also, doesnt have to do with the diff, but lately when i let off the clutch real slow and go to take off, the car kinda of like chugs, its hard to explain better to see in person. It like cuts in and out until it gets in higher rpm, some people told me flywheel. Don't know to much about the internal stuff so any help would be great......
Map Whack yo...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">
If your diff is whining, chances are that you have sheered off a couple teeth somehow. I would Replace the fluid and check for metal shaving when you drain it.</TD></TR></TABLE>
do we have magnetic drain plugs on our diff??? someone said we did, but if not purchase a set... i have them on my oil and tranny...
Old Oct 17, 2008 | 11:52 AM
ReddotsS2K's Avatar
Default Re: Differential (S2KILLA)
i believe the diff and tranny both have it
Old Oct 17, 2008 | 11:58 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">i believe the diff and tranny both have it</TD></TR></TABLE>
i was pretty sure one of them doesnt... correct me if im wrong...
Old Oct 20, 2008 | 05:09 PM
pli's Avatar
pli
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">
i was pretty sure one of them doesnt... correct me if im wrong...</TD></TR></TABLE>
ebay has a j's racing diff magnetic drain plug for 41 bucks.
Old Oct 20, 2008 | 07:08 PM
honeybadger's Avatar
If you are getting a clicking sound while accelerating you should check your axle spindle nut. It is a common problem with AP1's
Old Oct 20, 2008 | 07:18 PM
Black S2K's Avatar
the oem diff drain plug is magnetic i know for a fact.
fun4door
Suspension & Brakes
14
Nov 19, 2011 04:18 PM
DaredeVo
Honda S2000
Mar 28, 2010 03:56 PM
B18Cej1
11
Feb 20, 2007 03:20 PM
rasta420
Jul 2, 2002 08:22 PM
el_Presidente
Jan 30, 2002 06:15 PM
