Honda S2000 Honda S2000
condensation in the headlight
Old Dec 17, 2007 | 07:16 PM
ReddotsS2K's Avatar
Default condensation in the headlight
today i noticed that my damn left headlight are full of condensation. how do i get rid of it? what caused it?
Old Dec 17, 2007 | 07:59 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: condensation in the headlight (ReddotsS2K)
opening along the seal... best way is to open it back up, clean it then re-seal... if not wait till it gets warm again then just seal it after sitting in the sun for a while baking...
Old Dec 17, 2007 | 09:33 PM
LAS2K's Avatar
Default Re: condensation in the headlight (S@nt0s)
x2. Wait till its warm and little humidity out.
Old Dec 18, 2007 | 07:30 AM
wrice4's Avatar
take a sledge hammer and hit the hell out of the light, then go buy a new one
Old Dec 18, 2007 | 07:40 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (wrice4)
upgrade to ap2 lights
/thread
Old Dec 18, 2007 | 07:55 AM
papa5murf's Avatar
Shove it in the oven, bake it, open it up and reseal it.
Old Dec 18, 2007 | 07:56 AM
Black S2K's Avatar
^^ whatever you do dont do the downgrade to the ap2 lights.
Old Dec 18, 2007 | 08:41 AM
envee's Avatar
Don't forget to take the bulbs out of the healight if you are going to bake them...
Old Dec 18, 2007 | 10:02 AM
ReddotsS2K's Avatar
Default Re: condensation in the headlight (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Shove it in the oven, bake it, open it up and reseal it. </TD></TR></TABLE>
if im going to do that i mine as well do the clear diffusers to, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">^^ whatever you do dont do the downgrade to the ap2 lights.
dont worry i wouldnt put any gayp2 parts on my TRUE racecar
Old Dec 18, 2007 | 10:07 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">
Or go Naked!!
Old Dec 18, 2007 | 10:18 AM
ReddotsS2K's Avatar
damn i didnt know you could just do away with it. so once you bake it and pull it apart, how does the diffuser come out? what holds it in?
by the way you have the sexiest suzuka i have ever seen
Old Dec 18, 2007 | 10:43 AM
papa5murf's Avatar
^ Basically you take the headlight apart so that all is left is the headlight itself. bulbs out, HD ballast out. And you put it in the oven, you bake it. I'll look for a DIY for time and oven temp. Then you take it apart where the glue is. Clean it up. The Amber diffuser just pops out, it's attached by two or three clips (slide clips). And then you reseal it, make sure you have a couple of clamps, and clamp it down and let it sit for about 15-30 minutes. Then put the rest back together and back onto the car.
It's about a 4 hours process. This includes taking the lights off the car and putting them back on.
Old Dec 18, 2007 | 10:48 AM
papa5murf's Avatar
CLICK HERE
Old Dec 18, 2007 | 01:00 PM
ReddotsS2K's Avatar
thanks for the help
Old Dec 18, 2007 | 01:46 PM
jwa4378's Avatar
Here ya go. See the "S2000 Clear Diffuser Installation Instructions." Step-by-step. Oh, and NAKED FTW!
http://ricks2k.com/info/install.php
John
Old Dec 18, 2007 | 03:39 PM
b20integrapower's Avatar
Default Re: condensation in the headlight (jwa4378)
Well if you just need a temp fix to remove the condensation. Just remove the high beam bulb and let it sit in the sun for a while. I just left my high beam out all the time so i never had any water in there.
Old Dec 18, 2007 | 04:31 PM
negcamber's Avatar
b20integrapower is right...or if you are in the cold damp north right now, you can still bake with the bulbs pulled out...frequently though...the condensation will go away from just the baking so you don't need to pull them apart.
If you do bake and pull apart DO NOT touch the chrome coating around the headlight lens...it will come off very easily.
Do get the condensation out soon though. If you let it stay in there, the water will collect at the bottom of the light housing and corrode the leads to the ballast distroying it.
HeirApparent
Aug 31, 2008 07:06 AM
Ruben19
Lighting
Dec 13, 2007 09:34 PM
NorthernXposure
Apr 14, 2005 07:58 PM
xcom
Mar 3, 2004 05:10 PM
scoobyghost
10
Aug 8, 2003 08:18 AM
