Honda S2000 Honda S2000
Comptech Charger install
Old Aug 23, 2004 | 09:07 AM
AR Fab's Avatar
Default Comptech Charger install
Does anyone have their instructions for the install of this kit. Customer came in with the kit installed wrong and would like to have specs and install instructions for it. And how much Boost is the kit designed for. Right now its at 2-3psi...has a terrible stumble at 5-5.5K or so.....So far we found the BOV backwards! Im pretty sure the charger is done...from what Im understand the customer drove the car like this for a while...
Howard
Old Aug 23, 2004 | 09:53 AM
DCApex8's Avatar
Thankfully the F20C engine is built like Ford wishes Ford Tough was..So I'd doubt on such low boost that it'd have done too much damage.
I dunno how to install the kit though, sorry.
Old Aug 23, 2004 | 10:59 AM
AR Fab's Avatar
Default Re: Comptech Charger install (AR Fab)
I thought that the kit was built for 5-6 psi.
Old Aug 23, 2004 | 11:19 AM
Atheist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AR Fab &raquo;</TD></TR><TR><TD CLASS="quote">I thought that the kit was built for 5-6 psi.</TD></TR></TABLE>
Yea it is made for like 6psi.
I searched for and found the instructions for you:
SC is at http://www.comptechusa.com/instructions/ins072.pdf
if he has an aftercooler also, its at http://www.comptechusa.com/instructions/ins113.pdf
Old Aug 23, 2004 | 02:51 PM
AR Fab's Avatar
Default Re: Comptech Charger install (Atheist)
Thanks....I found it when I modified my search for it in Google.....
Who ever installed this kids kit really didnt open the booklet at all!!!
If anyone has this installed.....do you have a big stumble just before/during VTEC?
Howard
Old Aug 23, 2004 | 04:39 PM
ImportSport's Avatar
Try giving comptech a call during work hours. I have heard a number of people comment on how helpful their support staff is.
Old Aug 23, 2004 | 10:37 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AR Fab &raquo;</TD></TR><TR><TD CLASS="quote">Thanks....I found it when I modified my search for it in Google.....
Howard</TD></TR></TABLE>
was the FMU installed correctly too? Actually it doens't matter b/c it seems the entire kit wasn't installed right. I figure the ecu kept going into limp mode b/c it was seing boost via the map sensor. Make sure there's a voltage clamp on there. That will smooth things out. Not that cheap check valve that sits on top of the throttle body.
Old Aug 24, 2004 | 05:29 AM
AR Fab's Avatar
Default Re: Comptech Charger install (vapor)
it came with that ESM modifier thingy..lol..
I definetly dont like this Charger kit....Or atleast this particular one....im gonna put a few hours on it today...maybe Ill fix it...
Howard
Old Aug 24, 2004 | 06:53 AM
MooreBoost's Avatar
Let us know what turns up.
Old Aug 25, 2004 | 08:00 AM
AR Fab's Avatar
Default Re: Comptech Charger install (tegunderpressure)
Ok that EMS module that came with the kit was destroyed due to an improper installation.....It would clamp the MAP voltage at 3.9volts which needed to be clamped at 2.83v. This put the factory ECU in a default mode....When this happens the timing is totally out of wack and so is the fuel....INOP of VTEC...blah blah you name it....
We have a new voltage clamp on the way from Comptech...BTW they told us they never had one go bad...they were already throwing up the defensive wall even after we told them it was an installation error...makes me wonder about their warrantees on the kits....
Howard
BTW....on another note.... we just did the Ultimate racing kit in another customers car with an AEM backing it. AT 6psi the car did 302whp and 190fttq(tq is low due the our timing map)
The kit was designed for 8-9psi but we never saw that much boost on the WG. The kit in my opinion is a nice kit but needs to be priced alot lower for what you get. There are alot of Home Depot parts(plumbing) included that cost next to nothing and could be of a higher grade. Larger pipes and made aluminum would be nice and the DP could be alot nicer. The IC is a baby for the car we did(it has a body kit). The injectors are the old style Seimens Deka so Idle quality is not as nice as the newer Precision Injectors(but that keeps things easier w/o the use of a resistor pack)the WG and BOV are not what we would use.....TIAL only here. We can definetly do alot higher quality setup for the same price.
Howard
Old Aug 26, 2004 | 09:53 PM
evil vapor's Avatar
look for the supercharger mouting bracket to be sure it's not cracked or there aren't any cracks in it.
Old Aug 29, 2004 | 08:10 AM
AR Fab's Avatar
The Supercharger problem was fixed by purchasing a new EMS module and properly adjusting it....its all good now...
Howard
Old Aug 29, 2004 | 11:52 AM
SuzukaBlueAP2's Avatar
Default Re: (DCApex8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCApex8 &raquo;</TD></TR><TR><TD CLASS="quote">So I'd doubt on such low boost that it'd have done too much damage. </TD></TR></TABLE>
Boost is not what always kills an engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AR Fab &raquo;</TD></TR><TR><TD CLASS="quote">The Supercharger problem was fixed by purchasing a new EMS module and properly adjusting it....its all good now...
What kind of numbers are you expecting or does it put out?
Old Aug 29, 2004 | 02:16 PM
fknfast's Avatar
Default Re: (ScreaminTeg)
any other problems shoot me a PM we are the #1 comptech dealer in the US.
ill be glad to answer any ?s
PrecisionH23a
Dec 8, 2008 10:04 AM
Sassafrass
Apr 5, 2004 06:48 PM
