Honda S2000 Honda S2000
Clutch problems again
Old Jul 18, 2008 | 07:33 AM
TypeR324's Avatar
Default Clutch problems again
It has been slightly over a year since I had my clutch replaced at a Honda dealership. Ever since the clutch was installed I did not like it and I thought the catch point was WAY too high. I had brought it to the dealer right after they installed it and they said everything was fine. Well recently the catch point has been getting higher and higher. I ended up bringing the car to another Honda dealership to have it looked at. Outside of the catch point being high the clutch pedal feels almost crunchy or sticky for lack of better words. Its very strange because usually when I drive the car in the morning it feels fine. Then maybe 15-20 minutes later it starts to feel sticky and crunchy again. Then by the time I drive my car home from work it feels sometimes even worse most likely cause I use the clutch more in traffic.
I was hoping that the problem was the master cylinder or slave cylinder but Honda rulled that out yesterday when I brought the car there. They are telling me the only way to find the problem is to take appart the clutch which will cost $300 - $400 and then the same price to put it back together. I have called Honda customer support and they said there is a possiblity that they may cover the problem if the clutch was installed improperly. I didn't want to go back to the original dealer that installed the clutch cause they are terrible. Anyone ever had a problem like this or maybe just have an idea of what I should do? If I knew Honda won't cover the clutch I would just go and get a new clutch at Ballistic Motorsports for $950, as the dealer quoted me $2100!!!!
Modified by TypeR324 at 11:46 AM 7/18/2008
Old Jul 18, 2008 | 07:42 AM
ReddotsS2K's Avatar
Default Re: Clutch problems again (TypeR324)
mine is like that right now, Sometimes the pedal is really easy to press and feels real smooth, and sometimes is is hard to push and feels "crunchy" as you described. I figured it was just my slave cylinder. I might need to look into this also.
Old Jul 18, 2008 | 08:13 AM
TypeR324's Avatar
Default Re: Clutch problems again (ReddotsS2K)
The catch point will also shift sometimes its rediculously high sometimes kinda high. A Honda tech drove the car and also confirmed this, he seemed boggled. I just don't see how I could have caused the clutch to have this problem. I have probably only launched the car 3 times with the new clutch and maybe missed a gear once.
Old Jul 18, 2008 | 11:15 AM
b20integrapower's Avatar
check your fluid. I was low and had air in my lines and it felt like that. Bled the lines and everything was dandy
Old Jul 18, 2008 | 02:06 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Clutch problems again (b20integrapower)
clutch friction point being high is usually associated with a thin disc....or an improperly machined flywheel....see if the flywheel was machine or not.
I've done a few masters and slaves in S2K's also...seem to go bad quite often.
Old Jul 18, 2008 | 02:20 PM
TypeR324's Avatar
Default Re: Clutch problems again (Evs-One)
The flywheel was not machined I got a brand new one. I also know the dealer didn't screw me because I had them give me the old one.
Old Jul 18, 2008 | 02:50 PM
ReddotsS2K's Avatar
same here. everything was brand new for me. I have bled the clutch 3 times since the replacement and it still hasn't improved. Let me know what the outcome is, i would like to have the answer.
favd21
Transmission & Drivetrain
Sep 8, 2012 03:00 PM
Turbodude06
Nov 16, 2010 06:04 PM
TypeR324
Honda S2000
Sep 29, 2009 10:05 AM
dbman96
Feb 9, 2002 01:13 PM
dbman96
Feb 8, 2002 03:33 PM
