Honda S2000 Honda S2000
AP1 Torque Settings
Old Jun 27, 2007 | 04:21 PM
swimshady's Avatar
Default AP1 Torque Settings
S2000 AP1 Torque Specs for various bolts (in alpha order)
These were all taken from a Honda Service Manual First Edition 2000-2003 AP1 (revised 09/2002) ... they are all listed in lbf-ft and if says + xx* then tighten to the initial torque spec and tighten another xx degrees. Dont forget to tighten some bolts in an inside out pattern and multiple stages (such as head bolts, oil pan bolts, or lower block bolts just to name a few).
This is not a complete list, but as much as I could handle.
If you have any additions or changes, just let me know as these might not be 100% up to date.
Alternator Power Nut - 9
Alternator Pulley Locknut - 81.7
Alternator Support - 33
Belt Tensioner - 16 (to block)
Belt Tensioner Pulley - 31
Belt Tensioner Test - 19.3
Block Drain Bolt - 61
Brake Caliper Mounting Bolts - 79.6
Brake Hose/Line Fitting - 12
Cam Chain Auto Tensioner - 8.7
Cam Chain Sprocket Center Bolt - 36
Cam Chain Sprocket to Idler Bolts - 10
Cam Gear Nut - 86.8
Camshaft Holder Bolts - 16
Catalytic Converter Spring Bolts - 16
Clutch Bleeder Screw - 7.2
Clutch Line to Master - 11
Clutch Line to Slave - 22
Clutch Master Cylinder - 9.4
Clutch Pressure Plate - 19
Clutch Slave - 16
Connecting Rod Bolts - 18 + 90*
Crankshaft Pulley Bolt - 181
Cylinder Head Bolts (inside out) - 22 + 90* (or 22 + 180* if new bolts)
Cylinder Head Bolts (8mm Allen) - 22
Differential Bearing Cap Bolts - 33
Differential Breather Plate - 11
Differential Case (10 bolts) - 19
Differential Drain Plug - 33
Differential Filler Plug - 33
Differential Mounting Bracket Bolts - 33
Differential Mounting Bracket Nuts - 55
Driveshaft Bolts (Allen, 6 per side) - 24
Engine Control Module - 7.2
Engine Coolant Temp Sensor - 13
Engine Stop Bracket - 16
Engine Stop Bracket Cushion - 16
Exhaust/Cat Bolts - 25
Flywheel Bolts - 94
Front Camber Adjustment Bolt - 58
Front Lower Arm Flange Bolt (to set caster) - 58
Front Subframe Bolts (large) - 85.3
Front Subframe Bolts (small) - 43
Front Sway Bar - 61
Fuel Pressure Regulator - 7.2
Fuel Pulsation Damper - 16 (from feed line to fuel rail)
Fuel Tank Mounting Bolts - 33
Fuel Tank Unit (8 bolts) - 3
Fuel Tank Vapor Control Valve - 3
Half Shaft/ Output Shaft - 61
Header Bracket - 33
Header Stud Nuts - 23
Idler Pulley Base (large) - 33
Idler Pulley Base (small) - 8.7
Idler Pulley Bolt - 33
Ignition Coils - 8.7
Intake Air Temp Sensor - 4
Intake Manifold - 16
Lower Block Bolts (there are 16, inside out) - 22
Lug Nuts - 79.6
Main Bearing Caps - 22 + 60*
MAP Sensor - 1.5
Motor Mounts - 28 (to block)
Motor Mount Support Nut - 40
Oil Baffle Plate (windage tray) - 8.7
Oil Drain Plug - 29
Oil Filter - 16
Oil Jets - 12 (critical)
Oil Pan (tighten inside out in 3 steps) - 8.7 final
Oil Pump (small bolts) - 8.7
Oil Pump (large bolts) - 16
Oil Pump Chain Guide - 8.7
Oil Pump Sealing Bolt (spring loaded) - 29
Oxygen Sensor - 33
Power Steering Control Unit - 8.7
Power Steering Gearbox Mounting Bolts - 32
Radiator Fan Bolts - 5
Rear Ball Joint Castle Nuts (lower arms) - 51-58
Rear Camber Adjustment Bolt - 40
Rear Suspension Subframs Mounting Bolts - 43
Rear Wheel Spindle Nut - 181 (maybe 220, verify?)
Shocks (Rear Flange Bolt) - 47
Spark Plugs - 18
Steering Wheel Bolt - 29
Steering Knuckle Nut - 40
Thermostat Housing - 8.7
Throttle Body - 16
Tie Rod Locknut - 33
Timing Chain Cover (big bolts) - 33
Timing Chain Cover (small bolts) - 8.7
Transmission Bellhousing Bolts (upper x 3) - 47
Transmission Bellhousing Bolts (lower small x 2) - 33
Transmission Bellhousing Bolts (lower large x 2) - 47
Transmission Crossmember - 28
Transmission Drain Plug - 29
Transmission Fill Plug - 33
Transmission Mount - 28
Transmission Output Shaft Locknut (27mm) - 119
Valve Cover - 8.7
VTEC Oil Pressure Switch - 16
VTEC Solenoid Valve - 8.7
Water Bypass Tube Bolts - 8.7
Water Pump Housing - 33
Water Pump Pulley - 10
Old Jun 27, 2007 | 04:45 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: AP1 Torque Settings (swimshady)
for a bored guy.
Rear spindle nut is 220.
Modified by Mr. Projekt at 7:06 PM 6/27/2007
Old Jun 27, 2007 | 05:40 PM
SilverDc2's Avatar
Default Re: AP1 Torque Settings (Mr. Projekt)
this should be sticked on top
Old Jun 27, 2007 | 09:09 PM
alexisthemovie's Avatar
haha what a first post
alejandro_da9
Apr 10, 2014 07:37 AM
steve968
Honda Civic (2001 - 2005)
16
Aug 15, 2009 02:17 PM
BlueShadow
Aug 16, 2005 10:39 PM
poop32145432
Aug 6, 2005 02:10 PM
dabomb
Oct 5, 2003 07:05 PM
