Honda S2000 Honda S2000
Another ticking question
Old Jan 15, 2009 | 02:14 PM
MDMason's Avatar
Default Another ticking question
New S2000 CR. 1300 miles. Hearing a ticking that sounds like a tappet. I hear it primarily when coming to a stop from highway speeds, at idle. When I open the hood it sounds like it is coming from the firewall area, not the valve covers. Doesn't happen all the time. Did not have this issue on my previous 2000 model S2K. Any ideas?
Old Jan 15, 2009 | 02:24 PM
Boots's Avatar
Default Re: Another ticking question
take it to the dealer since it's still under warranty
Old Jan 15, 2009 | 02:28 PM
MDMason's Avatar
I took it to the dealer, I could not get it to tap dance on command. They of course had no idea what it could be.
Old Jan 15, 2009 | 02:33 PM
Boots's Avatar
check to see if there is a TSB on it...other than that, i don't know what to tell you bud
Old Jan 15, 2009 | 03:28 PM
tech7427's Avatar
its the evap solenoid
Old Jan 15, 2009 | 04:44 PM
bigmacnfries's Avatar
^^ care to expand on that a little?
is it normal or a bad thing? - i don't even know what an evap solenoid is - my car ticks in the same way as described, and i've never managed to trace it..
Old Jan 15, 2009 | 04:57 PM
tech7427's Avatar
just a guess but im pretty sure thats what he is explaining. its not valve train noise and on the ap1 its located on the right side of the IM. and it purges gas vapors into the intake to be burned and it clicks very fast, because its duty cycled and since its a solenoid its audible clicking and to the untrained ear it can be confused with valve train noise
Old Jan 15, 2009 | 05:28 PM
MDMason's Avatar
I'll explore this further, hopefully your right! Anybody know the location on the ap2?
Old Jan 16, 2009 | 04:45 AM
HondaKyle's Avatar
Its a monkey in side your dash...
Old Jan 17, 2009 | 07:26 PM
da9driverx's Avatar
i had the same problem with my ap2 and it was the timing chain tenstioner it would be silent until i drove it for while then it would start clicking between 1000 to 2500rpms and then i had a customer bring me his with the same problem fixed it and no more cliking i may add that both my s2k and my customers car have low miles!
Old Jan 18, 2009 | 07:50 AM
MDMason's Avatar
What did the fix involve? Was there a TSB on it? I contacted my dealer on Sat. Clueless!
Old Jan 18, 2009 | 03:59 PM
thanks for your help on that. 2 questions:
1. is it a problem?
2. what symptoms does it usually give out so i can make sure it is that? - i.e. does it when it's hot or cold, at certain revs etc. etc.?
any help appreciated..
Old Jan 19, 2009 | 11:02 PM
CHONCH2's Avatar
hmm strange. my mom's 03 cl type s has the same thing going on. keep us posted with what the outcome is.
Old Jan 20, 2009 | 06:49 AM
White Smoke's Avatar
i my honda
Global Mod
Does not sound like a TCT issue to me. That would clearly come from the front of the engine and sounds very very bad. It's about twice the speed as valve tick. Check youtube for "s2000 tct" to hear more.
I would record the car making the sound, with a cell vid or something. And then take it to the dealer. It does sound like it could be a solenoid issue of some kind. But I am not familiar with this issue.
Old Jan 21, 2009 | 09:03 AM
MDMason's Avatar
Thanks for the input, If I fiqure it out, I'll post.
Old Jan 27, 2009 | 03:05 PM
s2kap2rio's Avatar
good luck!
coolpop
Jul 28, 2013 08:32 PM
hgem1si
Apr 3, 2007 08:53 AM
Ray2943
Honda S2000
18
Sep 23, 2005 06:23 AM
FullEffect256
Jul 13, 2005 01:45 PM
Razor
Mar 13, 2002 06:43 AM
