Honda S2000 Honda S2000
ap2 timing
Old Jan 12, 2009 | 06:02 PM
crave13k's Avatar
Default ap2 timing
i have a quick question. my timing was off on my ap2 and i adjusted it but i think its still off because it kinda stumbles. anyway my question is the following: the arrow on the timing cover is supposed to line up with which line on the crank pulley. my pulley has 4 lines so i dont know which one to line it up with? any input will be appreciated.
Old Jan 12, 2009 | 09:08 PM
crave13k's Avatar
Default Re: ap2 timing
bump for some help
Old Jan 13, 2009 | 04:52 AM
joey1320's Avatar
hope this help. i got it from all data but i can't link the whole job unless you have a password...
http://alldatapro.com/alldata/PRO~V1...7075/117167076
http://alldatapro.com/alldata/PRO~V1...7075/117167077
Install the cam chain on the sprocket with the punch mark (A) aligned with the center of the two colored pieces (B). http://alldatapro.com/alldata/PRO~V1...7075/117167084
Old Jan 13, 2009 | 09:50 AM
crave13k's Avatar
yeah i cant see anything. the links wont work.
Old Jan 13, 2009 | 09:57 AM
joey1320's Avatar
oh **** sorry man.. is the best i can do. just pick up a cheap helms manual
Old Jan 13, 2009 | 02:39 PM
SuzukaBlueAP2's Avatar
can you screen shot this stuff and post those?
Old Jan 13, 2009 | 02:44 PM
joey1320's Avatar
i'll try i'm at work and everything is locked up here... give me a minute.
Old Jan 13, 2009 | 02:45 PM
no prob. just wondered.
Old Jan 13, 2009 | 02:48 PM
joey1320's Avatar
hope this helps!
Set the crankshaft sprocket so that the No.1 Piston is at Top Dead Center (TDC) . Align the key (A) on the sprocket and crankshaft with the pointer (B) on the engine block.
Install the cam chain with the colored piece (A) aligned with the punch mark (B) on the crankshaft sprocket.
Old Jan 14, 2009 | 04:31 AM
White Smoke's Avatar
i my honda
Global Mod
I am very confused about what you are doing... Your timing was off you say? Are you talking about base timing or ignition timing? How did you adjust the timing? Did you remove your timing chain? There are only two marks on the AP1 crank pulley and you are supposed to hit the red one on the right side with your timing light. Maybe I can give you some more help if you tell us what you did.
Old Jan 17, 2009 | 11:45 AM
crave13k's Avatar
yeah i took off the timing chain because it was way off. so this is the closest i could get it. i put white out on the marks so they could be seen in the pic. also if my timing is set close enough why does my obd scanner say my timing is advanced 8 deg when im running live data?
is this normal or did i make a mistake? thanks
Old Jan 17, 2009 | 04:15 PM
crave13k's Avatar
bump
Old Jan 18, 2009 | 12:17 PM
b20integrapower's Avatar
You would have MUCH better luck posting this over at s2ki. Just saying..no offense to anyone here.
Old Jan 20, 2009 | 08:01 AM
crave13k's Avatar
bump. does this look right?
Old Jan 20, 2009 | 02:02 PM
crave13k's Avatar
can anyone help?
Old Jan 21, 2009 | 06:17 AM
vollrathian's Avatar
i agree
Old Jan 21, 2009 | 07:27 AM
achan's Avatar
Originally Posted by vollrathian
i agree
yup
Old Jan 22, 2009 | 06:45 PM
Dc2Point2's Avatar
Are you getting any CEL'S? I have a PO140 Fuel trim malfunction and PO142 System running too rich. I checked mitchell on demand and it states to check camshaft timing. My simptoms: Under light acceleration (when It happens most) and cold weather the engine begins to bog out (cel comes on right away if I hold the accelerator), but if i shift right a way the bogging goes away and no cell light. I'm also thinking of checking the camshaft position sensor, but haven't had the time (Lazy if I may add).
My question to you is "Do you have any similar symptoms?"
Old Jan 27, 2009 | 10:52 AM
crave13k's Avatar
no im not getting those symptoms. but what i do get is a cel for "crank position sensor" and it wont let me rev past 3k. when i clear the code and get lucky i wont get that cel anymore but i will then get a "misfire cyl 2" & "secondary air injection system incorrect flow detected". i swaped the ckp sensor with a friend but it doesnt seem to make a difference. can anyone help?
Old Jan 27, 2009 | 11:41 AM
ExVtec's Avatar
Are you making sure that cylinder number 1 is @ top dead center when the marks are lined up?
Old Jan 27, 2009 | 01:01 PM
crave13k's Avatar
yeah if u look at the pic, when the arow is pointing at the white mark its at tdc.
Old Jan 28, 2009 | 05:38 AM
ExVtec's Avatar
But on which stroke?
I guess if it were 180 out it wouldn't even run...
Try a timing light to see where it stands.
another eg
Sep 9, 2015 02:04 PM
natebaur
May 17, 2009 10:35 AM
kixcrx
Sep 11, 2007 01:35 AM
MugenHonda
Jun 17, 2005 05:19 PM
Kirt Porter
Oct 8, 2004 09:10 PM
