Honda S2000 Honda S2000
Alignment Update!!!
Old Oct 25, 2007 | 08:20 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Alignment Update!!!
Ok, so the few people that actually read my first post about the horrible alignment job I had got will understand where Im coming from.... everyone else can read here:
https://honda-tech.com/zerothread?id=2090464
To sum it up this is what they gave me as an "alignment":
Camber
Front L -.5 R -.5
Rear L -1.5 R -1.6
Caster
Front L 3.2 R 5.5
Toe
Front L -.04 R -.04
Rear L .13 R .11
Well I finally got my new rims and tires put on and I def didnt want uneven wear so I decided to take it back. I talked to the guy and he said he wasnt able to do the UK spec because on the sheet it would not be in the specified range (.3-.7) so he said hed put it back to stock adjustments... i was fine with that... heres what I got now:
Camber
Front L -.5 R -.5
Rear L -1.4 R -1.5
Caster
Front L 5.9 R 5.9
Toe
Front L -.01 R -.01
Rear L .13 R .14
The only 2 numbers that were off were the Rear Camber and the Rear Toe. I cant really complain... plus the wheel is straight... plus the guy gave me a free oil change cause it was fucked the first time and i slipped a five spot so we were both happy... no way am i ****** taking my car to get an oil change there though... ill take the wifeys
Old Oct 25, 2007 | 08:35 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Alignment Update!!! (S2KILLA)
never take it to that place again .... they dont need a sheet u tell them what you want ad they do it plain and simple...
i dont know how many times i have gone to a place and told them what i wanted or wrote it down on a piece of paper...
u are paying them so they should give u what u are asking for.....
Old Oct 25, 2007 | 09:00 AM
S2KILLA's Avatar
Default Re: Alignment Update!!! (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">never take it to that place again .... they dont need a sheet u tell them what you want ad they do it plain and simple...
u are paying them so they should give u what u are asking for.....</TD></TR></TABLE>
I know, but they cant give a car back with any numbers that are out of there spec... if I got into an accident they could be blamed for it or some **** the guy was saying... Well I already got 2 alignments from them so it kinda payed for itself... From now on Ill take it to a legit place and spend the extra money... the one guy was helpful though...
Old Oct 25, 2007 | 09:11 AM
papa5murf's Avatar
You know, since you're in NJ's, you should just make a road trip down to VA, and go to Ptuning. In ground alignment system, they'll set you up with whatever alignment spec you want.
Old Oct 25, 2007 | 09:22 AM
S2KILLA's Avatar
Default Re: Alignment Update!!! (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">You know, since you're in NJ's, you should just make a road trip down to VA, and go to Ptuning. In ground alignment system, they'll set you up with whatever alignment spec you want. </TD></TR></TABLE>
reaaaalllllllly?!?! how much does an alignment run from them?
Old Oct 25, 2007 | 10:17 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">
reaaaalllllllly?!?! how much does an alignment run from them?</TD></TR></TABLE>
They were charging $95 as a special for s2000 owners in the month of October. http://www.s2ki.com/forums/ind...31398
I'm not quite sure how much they charge on a regular basis. The shop just opened up not too long ago, but their alignment setup is definitely
It should be about a 2.5-3 hour drive for you.
wannaBjdmca6
Suspension & Brakes
29
Jan 22, 2011 08:52 AM
TurboEM1
Suspension & Brakes
10
Mar 31, 2006 05:12 AM
2000turbosi
Suspension & Brakes
Mar 26, 2006 08:24 AM
AzntaggeR
18
May 1, 2004 03:21 AM
01CWITR
Aug 6, 2002 05:32 PM
