Honda S2000 Honda S2000
AEM EMS + Comptech SC
Old Dec 13, 2006 | 03:30 PM
oni3's Avatar
Default AEM EMS + Comptech SC
Hey all, I hate to pull you away from that sweet ROTA thread and the lots of love that's happening in there, but I have another question(s). Thanks for taking the time to pause on the ROTA bashing amd help.
I was thinking, should something sway my mind on getting the Lovefab kit I'd deffinatly go with the Comptech SC w/ aftercooler. I know if I did this I wouldn't *need the AEM EMS, but I'd still *want it because well... EMS's are great. However what would be the benifits of having it with the Comptec SC vs. not having it? Would it be worth all that money if it wasn't *needed?
Old Dec 13, 2006 | 05:23 PM
Curiouz_G's Avatar
basically your question is can you skimp out on a ems like AEM EMS and just go another cheaper EMS and still make the same power? the answer is..... i honestly cant tell you. Twizted on s2ki says you can use greddy ultimate and still get 400+whp on turbo applications. not so sure about SC applications. but my question to you is, why would you skimp on the most important part of a kit?
Old Dec 13, 2006 | 06:13 PM
immortal's Avatar
Banned
Default Re: (Curiouz_G)
you dont need an AEM EMS for a comptech sc /w ac on stock or near stock boost levels.
the thing about the AEM EMS is that if you dont get it perfectly tuned, your car will never run the way it used to. colder weather, hotter weather, elevation... etc all will play a part on your tune and the way the car drives. your part throttle settings will never be like the oem ECU either. keeping the oem ecu + adding a piggy back is the best option in my opinion unless you can spend butt loads of money on dyno tuning with a competent tuner. if you have access to both the latter, i would go for the AEM..
but really, if you aren't boosting above 10psi it'd be a waste imo.
Old Dec 13, 2006 | 07:10 PM
Mase's Avatar
Default Re: (immortal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immortal &raquo;</TD></TR><TR><TD CLASS="quote">you dont need an AEM EMS for a comptech sc /w ac on stock or near stock boost levels.
but really, if you aren't boosting above 10psi it'd be a waste imo. </TD></TR></TABLE>
I completely disagree.
Think about the fuel system it comes with. All it does is hides boost from the stock ecu, and jacks up the fuel pressure to unsafe pressures.
Ignition timing is vital when it comes to Boosted high compression motors.
You'll make more power and be much safer w/ an standalone.
And If the AEM is tuned correctly, you most likely wont be able to tell there is even an aftermarket ecu plugged in.
Old Dec 13, 2006 | 09:02 PM
immortal's Avatar
Banned
Default Re: (Mase)
yeah but on a comptech with stock boost levels i dont see the need to spend another $1500-2000 when it's not needed. money doesnt grow on trees for a lot of people.
on a turbocharged car i would go standalone no doubt about it.
Old Dec 14, 2006 | 06:17 AM
Curiouz_G's Avatar
if you cant afford to play with the big boys, then done pretend. boosting a s2000 isnt cheap.
Old Dec 14, 2006 | 06:59 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G &raquo;</TD></TR><TR><TD CLASS="quote">if you cant afford to play with the big boys, then done pretend. boosting a s2000 isnt cheap. </TD></TR></TABLE>
boosting any car the "right" way isn't cheap.
Old Dec 14, 2006 | 09:06 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: AEM EMS + Comptech SC (oni3)
These topics always end up the same... and I ran out stupid **** to say for today.
Old Dec 14, 2006 | 09:11 AM
M.A.R.C.'s Avatar
Default Re: AEM EMS + Comptech SC (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">These topics always end up the same... and I ran out stupid **** to say for today.</TD></TR></TABLE>
sure bout that?
Old Dec 14, 2006 | 09:33 AM
blkturbos2k's Avatar
Default Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
And If the AEM is tuned correctly, you most likely wont be able to tell there is even an aftermarket ecu plugged in.</TD></TR></TABLE>
Im with you. If the AEM is tuned right it will run like a OEM ecu. my car runs great at 1/2 thro.
Old Dec 14, 2006 | 02:49 PM
oni3's Avatar
Default Re: (blkturbos2k)
It's not that I'm trying to skimp on anything. I'm just trying to see if it's justified with only having stock internals and running the base PSI of the Comptech SC. I'm only looking to make ~330whp.
Old Dec 14, 2006 | 03:00 PM
texx's Avatar
The EMS is a better option. Once you get the tune done your set. Now if you start adding things such as exhaust or run cool parts, then yes, it's time to tune again. The EMS also gives you lots of insight and troubleshooting capabilities. I don't know about every car but it only took me about 2 hours to tune.
Old Dec 14, 2006 | 05:52 PM
oni3's Avatar
Default Re: (texx)
Yes, I understand the advantages of having it. I run a Hondata s200 system on my Civic. I'm looking for more of the technical side of things, like how well the AEM EMS works with the Comptech SC, or something along the lines of "yes, it's a great mod, but will not benifit you enough to warrant the $2500 price tag."
Old Dec 15, 2006 | 02:52 AM
M.A.R.C.'s Avatar
Default Re: (oni3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oni3 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I understand the advantages of having it. I run a Hondata s200 system on my Civic. I'm looking for more of the technical side of things, like how well the AEM EMS works with the Comptech SC, or something along the lines of "yes, it's a great mod, but will not benifit you enough to warrant the $2500 price tag."</TD></TR></TABLE>
it's a standalone ems.... it's 100% tunable. it's hard to say that it's a "great mod" cause it's not like a bolt on... any ems is only as good as the tuner can tune it or as good as the setup is.
Old Dec 15, 2006 | 01:06 PM
kangaroo's Avatar
My dad spent 17K on his s2k and only managed to pull 293whp. Was hopeing for 330whp+ but nope.
I don't think you need the AEM EMS with a stock comptech system.
SAD SAD SAD.
Old Dec 15, 2006 | 01:52 PM
MidwestAutoWorks's Avatar
Default Re: (kangaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kangaroo &raquo;</TD></TR><TR><TD CLASS="quote">My dad spent 17K on his s2k and only managed to pull 293whp. Was hopeing for 330whp+ but nope.
SAD SAD SAD.
he was hoping for that on stock 5.5 psi boost?
Old Dec 15, 2006 | 01:58 PM
kangaroo's Avatar
Default Re: (MidwestAutoWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">
he was hoping for that on stock 5.5 psi boost?</TD></TR></TABLE>
actually we got the 3.9inch pully which is about 7psi.
you don't even want to see all the other parts we got and still only managed to pull 293whp.
Old Dec 15, 2006 | 03:51 PM
M.A.R.C.'s Avatar
SAD SAD SAD.
i blame the setup or the tuner. then again. it's a blower on an S it's not gonna make that much. a local guy here was making ~350whp @ 11psi on a vortech kit (i think) tuned by a reputable tuner. so i dunno. this local tuner tunes conservatively so maybe it coulda squeezed a bit more but i dunno.
Old Dec 15, 2006 | 07:37 PM
kangaroo's Avatar
Default Re: (M.A.R.C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M.A.R.C. &raquo;</TD></TR><TR><TD CLASS="quote">
i blame the setup or the tuner. then again. it's a blower on an S it's not gonna make that much. a local guy here was making ~350whp @ 11psi on a vortech kit (i think) tuned by a reputable tuner. so i dunno. this local tuner tunes conservatively so maybe it coulda squeezed a bit more but i dunno.</TD></TR></TABLE>
Was that on a stock motor?
I think the set-up is pretty solid.....I was pissed as hell when the # came back so low. I'm not positive but I do kind of blame the tunner. Maybe we just need to up the boost.?? but I don't want to do that to a stock motor.
Old Dec 16, 2006 | 06:53 AM
M.A.R.C.'s Avatar
I think the set-up is pretty solid.....I was pissed as hell when the # came back so low. I'm not positive but I do kind of blame the tunner. Maybe we just need to up the boost.?? but I don't want to do that to a stock motor.</TD></TR></TABLE>
the motor had a headgasket and that was it.
plzhitvtec
26
Oct 8, 2004 02:44 PM
98whtR
Jul 24, 2003 08:07 AM
B18C_eg
30
Dec 19, 2002 10:52 AM
B18Redline
Nov 22, 2002 04:52 AM
TITEB16
16
Aug 31, 2001 12:22 PM
