92 Eg si won't start key problem?
I was driving my car the other day was running fine when I got home went to go start it again and none of my dash lights and fuel pump didnt come on but it still turns over with thr push start button
Re: 92 Eg si won't start key problem?
I don't think the main relay would cause the dash light not to come on??
But still...listen for the 'clicking' sound when you turn the key to on.
Ya I think its the ignition switch the electical part I took it apart at the switch looks kind bad ill post a pic when I get off work
the same thing happend to my car last week i got a new battery didnt work new spark plugs checked the timing nothing worked took it in and it was a sensor in the distibutor that is easy to over look and cant check it unless you put a new one on or diffrent distibutor on so i got a new distibutor and it started up right away i would consider trying that see if a friend has on you could barrow or get a new one
cleanM1
05-03-2012 10:31 AM
