Wheel Hopping?
Old Feb 20, 2004 | 07:14 PM
BlackJRSCTeg's Avatar
Default Wheel Hopping?
My buddy has a 98 prelude with i/e and others. He has 18's with low profile tire would that cause it to wheel hop?
Old Feb 21, 2004 | 01:12 AM
tylek17's Avatar
Default Re: Wheel Hopping? (BlackJRSCTeg)
new stiffer shocks i recommend the kyb agx's
Old Feb 21, 2004 | 02:17 AM
stoopid215's Avatar
What the heck is wheel hop ?? Chirpping tires?!?!??!
Old Feb 21, 2004 | 03:28 AM
Default Re: Wheel Hopping? (stoopid215)
not spinning the tires but it bounces or jars for front end around.... its real rough on his axles.
Old Feb 21, 2004 | 03:36 AM
shinra's Avatar
i thought wheel hop happens when your tires don't get enuff traction on a launch?
Old Feb 21, 2004 | 04:03 AM
Default Re: Wheel Hopping? (shinra)
i have people telling me he needs front motor mounts....higher profile in tires..... and stiffer shocks... which sounds more reasonable? i have heard of motor mounts stopping the wheel hop problem....
Old Feb 21, 2004 | 07:30 AM
Greyout's Avatar
get j00 a set of these
http://www.opmautosports.com/p....html
motor mounts will help a little bit...
also keep the tire pressures up
smaller rims wouldn't hurt
Old Feb 21, 2004 | 07:38 AM
satan_srv's Avatar
Default Re: Wheel Hopping? (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">get j00 a set of these
Can you explain these a little more? Wheel hop is my enemy!
Also aftermarket springs and shocks will also fight wheel hop
Old Feb 21, 2004 | 07:42 AM
PreludePimp's Avatar
My damn stock celica does this in first gear
Old Feb 21, 2004 | 09:03 AM
BoostedH23a1's Avatar
i get some through 3rd back when i had the 18s
Old Feb 21, 2004 | 09:44 AM
RAB's Avatar
RAB
Default Re: (BoostedH23a1)
Lower the tire pressure and no more wheel hop.
Old Feb 21, 2004 | 09:51 AM
pwrofdrm's Avatar
Default Re: (RAB)
Energy Suspension Motor Mount Inserts
Pretty cheap, work well.
Old Feb 21, 2004 | 09:56 AM
Greyout's Avatar
Default Re: (RAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAB &raquo;</TD></TR><TR><TD CLASS="quote">Lower the tire pressure and no more wheel hop.</TD></TR></TABLE>
last time I was at the track I found the opposite to be true.
I lowered tire pressure to increase traction - my 60's stayed the same, but wheel hop got much worse
Old Feb 21, 2004 | 10:43 AM
duderlude12's Avatar
the way i eliminated wheel hop at the track was to buy some 14s and put some mickey's on them. this made my launches incredible with no wheel hop and it also knocked about .3 off my ET. i got the wheels and tires for a total of $300. It is an awesome investment.
Old Feb 21, 2004 | 09:09 PM
2point2's Avatar
Default Re: Wheel Hopping? (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">Can you explain these a little more? Wheel hop is my enemy!</TD></TR></TABLE>
He hasn't replied in a while so i'll give this a shot..
Drive your car on a hoist and you'll see how much your radius rod bushings compress with acceleration.. (even on the hoist without the weight of the car!!) these solid bushings will keep your caster from loading and unloading (wheelhop) under acceleration.. popular mod for the EF's because they share the same suspension as prelude/accords - might be pretty rough on the street when you hit a pothole and you'll feel it when you hit a gear hard!!
i'm certain that your rr bushings are shot with the amout of power your putting to the ground. These bushings give exactly the same effect as a 'traction control' unit would for the civics but a hell of alot cheaper for the exact same effect. It's also adjustable which is a huge + because you can dial in your alignment perfectly. I seriously can't beleive the price of these things.. i think it's a great upgrade for high power ludes.
Old Feb 22, 2004 | 08:54 AM
satan_srv's Avatar
Default Re: Wheel Hopping? (2point2)
Yeah I'm picking up a set.
I got a lot of information here https://honda-tech.com/zerothread?id=774968
And found a better designed one.
zachhthe1
15
Apr 22, 2014 09:20 PM
b16a27
Mar 4, 2005 09:18 AM
Sinner
Sep 12, 2004 06:00 PM
Thirty-Nine
Jan 20, 2004 08:12 PM
RTW DC2R
Jan 16, 2002 10:30 AM
