Clunk noises
Old Feb 16, 2003 | 12:01 AM
rexorz's Avatar
Default Clunk noises
I'm driving regulary and as I slow down, i hear some type of clunk noise comming from the engine bay. what could it be? i have no clue what's wrong wit the car.
Old Feb 16, 2003 | 01:30 AM
pentaq's Avatar
Default Re: Clunk noises (Rexorz)
Inner CV joints are worn.
[Modified by pentaq, 10:30 AM 2/16/2003]
Old Feb 16, 2003 | 05:34 AM
Shakes's Avatar
space cadet
motor mounts starting to go. the engine will flex more.
Doug
Old Feb 16, 2003 | 08:49 AM
rexorz's Avatar
Default Re: Clunk noises (shakes)
motor mounts? the car is like new. 9k miles, 2001.
Old Feb 16, 2003 | 10:25 AM
Shakes's Avatar
space cadet
i never said it was likely.... just a posibility. maybe they were bum from the start. shitty deal if they were. most likely they are fine. i was just throwing in an idea.
Doug
Old Feb 16, 2003 | 10:37 AM
satan_srv's Avatar
motor mounts wouldn't clunk when slowing down...more like when you apply load...
Old Feb 16, 2003 | 04:11 PM
Shakes's Avatar
space cadet
Default Re: Clunk noises (satan_srv)
when i had my POS saturn... my upper motor mount went bad. it would clunk like crazy at idle. when i would apply the gas it slowed down. i guess the engine flex moved the rubber just right or something and it would stick. after a while yes it got much louder when i hit the gas and as the mount broke more.
Doug
[Modified by shakes, 1:12 AM 2/17/2003]
Old Feb 16, 2003 | 11:32 PM
rexorz's Avatar
i would only hear the clunk when im slowing down. i dont hear it at idle or anything, also i hear some whining noise commin from the motor.. im thinkin its something that has to do wit the timing belt, but not sure. could that have to do anything wit the clunk?
Old Feb 18, 2003 | 08:15 AM
EBP5THGEN's Avatar
It is probably the control arm bushing or knuckle assembly. Mine has the same issue and the dealership, after hours of testing, narrowed it down to one of those things.
Old Feb 18, 2003 | 01:35 PM
rexorz's Avatar
Default Re: Clunk noises (EBP5THGEN)
they found out that my sway bar is bent and isnt connected cuz its bent and wont connect back on the drivers side. so im getting new sway bars and going to see how that goes.
B20HmongHatch
Jun 26, 2012 02:25 PM
ef602
Apr 13, 2009 12:15 PM
rob[CB7]
Jun 12, 2008 04:50 AM
95lsinteg
Feb 7, 2004 12:08 AM
blueeg
Aug 6, 2003 03:35 PM
