Weird idle
Old Sep 16, 2007 | 07:39 PM
LukieLuc's Avatar
Default Weird idle
hey guys i have a wired idle problem, when ever i press the clutch to come to a stop, or to go into neutral, my idle drops down to 500 rpms and pops back up quickly to 650 or 750rpm (normal idle). I cleaned the idle air control valve, and it still does it. Do you guys have any insight into this
Old Sep 16, 2007 | 08:46 PM
LukieLuc's Avatar
Default Re: Weird idle (LukieLuc)
up
Old Sep 16, 2007 | 09:00 PM
preludefien
Guest
Posts: n/a
any vacum leaks and codes. the fast idle valve is on cold start up but it could be that...as i delt with the same ****. so just put your finger over ther whole in the throttle body and if it idles normal then thats your prob. mgags made a nice read up on idle bouncing. search for it
Old Sep 17, 2007 | 11:31 AM
LukieLuc's Avatar
Default Re: Weird idle (preludefien)
it only does it when i go into neutral, when moving or coming to a stop
what other things affect the idle in this situation?
It doesn't happen when i am standing still.
Old Sep 18, 2007 | 03:42 AM
LukieLuc's Avatar
need some suggestions!!!!
Old Sep 18, 2007 | 02:18 PM
LukieLuc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">need some suggestions!!!! </TD></TR></TABLE>
Old Sep 18, 2007 | 02:31 PM
IAluder95's Avatar
i had this problem, never did figure it out. my head gasket blew tho!
Old Sep 19, 2007 | 09:31 AM
LukieLuc's Avatar
Default Re: (IAluder95)
After you changed your head gasket did the problem continue?
Old Sep 19, 2007 | 10:06 AM
DarkBB4's Avatar
Default Re: (LukieLuc)
same probem luc... It always seems like it wants to stall, but the rpms just climb back up to 700-750 after dropping to around 500
ANNOYING!!
Old Sep 19, 2007 | 02:02 PM
LukieLuc's Avatar
Default Re: (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">same probem luc... It always seems like it wants to stall, but the rpms just climb back up to 700-750 after dropping to around 500
ANNOYING!!</TD></TR></TABLE>
Yea it is sooooo annoying. Do you think there's a way to fix the problem? And does it hurt the motor, when it does this??
Old Sep 19, 2007 | 03:07 PM
DarkBB4's Avatar
i have no idea...
Im debating whether to jsut raise the idle slightly
Old Sep 19, 2007 | 04:03 PM
BB1 H22A LUDE's Avatar
Hey, I have noticed the same thing happen every time i release the clutch or even release the gas pedal. I think it has some thing to do with the removal of the factory intake hose and resonator. Once we change gear or release the gas pedal, the throttle's valve closes and shuts of the throttle body from the air intake pipe and allows little free flowing air to pass. Its almost like the longer pipe length and wider than factory diameter intake pipe doesn't promote flow of air at such low Rpm's and hence the vacuum or suction is high(probable due to the large diameter intake pipe and the lack of air reserves(the small black loop thing'y that runs down the bottom of the factroy intake hose near throttle body)).
SO basiclly what im trying to say is that the car suffocates and doesn't get enough air (or fuel) and hence the drop in Rpm, but then the ECU detects this and increases air flow and fuel to recover the lost Rpm. Its kindoff like being at sea drifting around, every time your head goes under (the Rpm drops) u lack air and then respond to that by trying to resurface (using energy-maybe fuel) and getting your head above sea level again (ECU innervating to raise Rpm). Well thats my logic behind it any way. Factory ludes tend not to do it, so im gona put this one on bolt on's. Thats all i could come up with, dont know if it damages the engine, probably not due to the ecu preventing stalling or a significant rpm drop.
Old Sep 19, 2007 | 04:28 PM
DarkBB4's Avatar
Default Re: Weird idle (BB1 H22A LUDE)
i think it might have something to do w/ my p28
Old Sep 19, 2007 | 07:19 PM
NtheWorks's Avatar
adjusting my base idle made mine quit
Old Sep 19, 2007 | 07:37 PM
LukieLuc's Avatar
Default Re: (NtheWorks)
what you turned the idle screw?? or adjusted the idle through the ECU?
Zee.I
Jul 11, 2021 11:36 PM
`chrisb
May 4, 2008 01:46 PM
spock_rocker
Oct 17, 2007 08:11 AM
killa_lude
Aug 16, 2003 08:33 AM
Fatty_1775
Aug 6, 2003 05:32 PM
