VTEC light/indicator
If you mean a light that would indicate if the vtec is engaged, it would be easy to make. If you have the wiring diagram, you would put an LED and a 2-4k ohm resistor in parallel with the solenoid wire and ground then wire it to wherever you like. Don't forget to put the correct end towards the + wire of the solenoid.
