RPM - Tach
Old Jan 21, 2007 | 06:26 AM
b16a4's Avatar
Default RPM - Tach
Hello all, i have installed a vtec controller.
i have set the vtec point to engage at 5800rpm on the vtec controller.
But when i watch my tach on the dash, the vtec actually engages at about 6000-6100rpm.
The rpm from the vtec controller does not match the rpm on the dash.
What could be wrong?
Old Jan 21, 2007 | 07:22 AM
bart2546's Avatar
Default Re: RPM - Tach (b16a4)
Well the stock tach in the gauge cluster is generally HORRIBLY wrong. But also on the controller make sure that you did do the initialize option so you're not running it on some other setting if you bought it used. The other thing is to make sure you're running it according to a 4 cylinder with the fuel curve arrow going in an up direction. When I first installed mine it somehow set itself to a 6 cylinder which was weird to say the least. It is generally right on track once I set it to the 4.
Old Jan 21, 2007 | 08:33 AM
b16a4's Avatar
Default Re: RPM - Tach (bart2546)
i know its off, but before my vtec used on at 5800 and i can see it correct on the tach.
efHatchbackJake
13
Apr 8, 2005 12:05 PM
CimorelliCRX
Mar 18, 2003 07:20 AM
CimorelliCRX
Mar 11, 2003 03:54 PM
NightHawkC5
Feb 12, 2003 11:51 AM
JDM 007
May 27, 2002 02:02 PM
