Trick to getting the flywheel off?
Old Apr 16, 2003 | 09:19 AM
Greyout's Avatar
Default Trick to getting the flywheel off?
is there a trick to getting the flywheel off without breaking something
Old Apr 16, 2003 | 09:26 AM
laughinxxx's Avatar
New User
Default Re: Trick to getting the flywheel off? (JDM LUDE)
Wedge a 2x4 against the flywheel and the frame of the car. Lay on your back, push the board up with your chest, in order to hold the flywheel in position, and break the bolts loose.
Or you could go to Honda and buy the right tool for the job.
I went with the former after going to every autoshop in the area and not finding the tool that I needed(Honda was closed already for the day).
Old Apr 16, 2003 | 09:34 AM
Greyout's Avatar
Default Re: Trick to getting the flywheel off? (laughinxxx)
the engine is out of the car.
There is a special tool for THIS? what does it do?
Also, it seems like there is no exact right size socket that fits it (I know its a 12-point)
Old Apr 16, 2003 | 09:46 AM
flyrod's Avatar
Screw one of the large tranny bolts into the engine block. Cut a peice of wood so that it can catch the teeth of the ring gear on the flywheel and wedge against the large bolt. Or else set the crank with a piston half way up on compression and fill the cylinder with oil through the spark plug hole and put the spark plug in. I've had to do this to remove the crank pulley bolt. And yes, there are special tools from honda if you prefer... and the socket you need is a 12-point 17mm.
Old Apr 16, 2003 | 09:47 AM
2point6's Avatar
the flywheel bolts are 17mm 12point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM LUDE &raquo;</TD></TR><TR><TD CLASS="quote">the engine is out of the car.
Also, it seems like there is no exact right size socket that fits it (I know its a 12-point)</TD></TR></TABLE>
Old Apr 16, 2003 | 09:49 AM
laughinxxx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM LUDE &raquo;</TD></TR><TR><TD CLASS="quote">1. the engine is out of the car.
2. There is a special tool for THIS? what does it do?
1. Lucky bastard.
2. It screws into one of the mounting holes and has a pointer that fits inbetween the teeth of the flywheel.
Old Apr 16, 2003 | 09:56 AM
95hbMatt's Avatar
I just did this a couple days ago....I used a prybar and wedged in in between the flywheels teeth...I put one of the tranny bolts back in for the prybar to rest on...did it all by myself..pretty easy! You might have to lean against the motor to keep it from moving since it is out of the car....
Old Apr 16, 2003 | 10:14 AM
Greyout's Avatar
Default Re: Trick to getting the flywheel off? (95hbMatt)
cool, thanks guys
Old Apr 16, 2003 | 10:15 AM
prelude1897's Avatar
Air tools would be the easiest way to get your flywheel off. If you can get your hands on someones air compressor and impact wrench, then you can do the job alot faster and easier
SIRIUS VTEC
16
Aug 10, 2010 07:57 PM
.Thomas
Jan 16, 2007 10:45 PM
slmmdnissan
Jul 14, 2004 01:03 PM
rOby
Dec 29, 2002 07:43 AM
Scooby
Jun 28, 2002 01:07 PM
