Torque Specs For 5th Gen Preludes.
Old 04-12-2013, 02:30 PM
NickGREPSMN's Avatar
Default Torque Specs For 5th Gen Preludes.
Air Bag
Airbag Assembly
Drivers Side Torx Bolt(s) 9.8 Nm
Passengers Side Lower Mounting Nut(s) 9.8 Nm
Air Bag Control Module
SRS Unit
Torx Bolt(s) 9.8 Nm
Alignment
CAMBER Front 0°00' ±1°
Rear -0°45' ±1°
CASTER Front 4°20' ±45'
TOTAL TOE Front 0 ±2 mm (0 ±1/16 inch)
Rear IN 2 ±2 mm (1/16 ±1/16 inch)
FRONT WHEEL TURNING ANGLE Inward Wheel 34°50' ±2°
Outward Wheel 28°50'(Reference)
Fill Plug, A/Transmission
TIGHTEN TO 49 Nm (36 ft. lbs.)
Auxiliary Air Valve (Idle Speed)
Torque 7.2 ft.lb
Axle Shaft
DIMENSIONS
Left Driveshaft 484-489 mm (19.1-19.3 inch)
Right Driveshaft 493-498 mm (19.4-19.6 inch)
Brakes and Traction Control
Brake Bleeding
Bleed Screw 6 ft.lb
Brake Caliper
Front Banjo Bolts 25 ft.lb
Bleed Screw 6.5 ft.lb
Caliper Bolts 36 ft.lb
Bracket Bolts 83 ft.lb
Rear Banjo Bolt 25 ft.lb
Bracket Bolts (10 mm) 28 ft.lb
Caliper Bolts 17 ft.lb
Flange Bolts (8 mm) 17 ft.lb
Parking Nut 20 ft.lb
Brake Hose/Line
TORQUE SPECIFICATIONS Line-to-Hose 15 Nm (11 ft. lbs.)
Master Cylinder-to-Line 15 Nm (11 ft. lbs.)
Proportioning Control Valve-to-Line 15 Nm (11 ft. lbs.)
ABS Modulator Unit-to-Line 15 Nm (11 ft. lbs.)
Brake Pad
Front Rear
Brake Pad Thickness Standard 0.41 - 0.44 in 0.33 - 0.35 in
Service Limit 0.06 in 0.06 in
Brake Pedal Assy
GENERAL SPECIFICATIONS Pedal Height [1] :M/T 161 mm (6 5/16 inch)
A/T 166 mm (6 9/16 inch)
Free Play 1 - 5 mm (1/16 - 3/16 inch)
[1] With carpet removed.
Brake Rotor/Disc
Front Brake Disc Runout Service Limit 0.004 in
Max. Refinish Limit 0.83 in
Wheel Nut 80 ft.lb in
Brake Disc Thickness Standard 0.90 - 0.91 in
Max. Refinishing Limit 0.83 in
Brake Disc Parallelism 0.0006 in
Rear Brake Disc Runout Service Limit 0.004 in
Max. Refinishing Limit 0.31 in
Brake Disc Thickness Standard 0.35 - 0.36 in
Max Refinish Limit 0.31 in
Parking Brake Lever
Play In Stroke [1] To Be Locked When Pulled 6 - 10 Notches
[1] At 196 N (20 kgf, 44 ft. lbs.) lever force.
Vacuum Brake Booster
Brake Line Flange Nuts 15 Nm (11 lb. ft.)
Master Cylinder To Booster 15 Nm (11 lb. ft.)
Booster To Firewall Nut 13 Nm (9 lb. ft.)
Catalytic Converter
Exhaust Pipe A to Catalytic Converter 24 ft.lb
Converter to Exhaust Pipe B 24 ft.lb
EGR Valve
Torque 16 ft.lb
Exhaust Manifold
Cover Bolts 22 Nm (16 ft. lbs.)
Lower Bracket Bolts 44 Nm (33 ft. lbs.)
Manifold-To-Exhaust Pipe 54 Nm (40 ft. lbs.)
Mounting Bolts 31 Nm (23 ft. lbs.)
Exhaust Pipe
Converter-To-Exhaust Pipe B 33 Nm (24 ft. lbs.)
Exhaust Pipe A-To-Catalytic Converter 33 Nm (24 ft. lbs.)
Exhaust Pipe A Bracket Bolt 38 Nm (28 ft. lbs.)
Exhaust Pipe A Clamp Bolts 22 Nm (16 ft. lbs.)
Exhaust Pipe B-To-Muffler 54 Nm (40 ft. lbs.)
Manifold-To-Exhaust Pipe A 54 Nm (40 ft. lbs.)
Fuel Pressure Regulator
Torque 9 ft.lb
Fuel Pump
Torque 4.3 ft.lb
Fuel Rail
Torque 8.7 ft.lb
IDLE SPEED
Controled Idle Speed
Man. Trans. 700 RPM Auto Trans. (N) 700 RPM
Manifold Pressure/Vacuum Sensor
Torque 1.5 ft.lb
Manual Transmission (Basic)
Drain Plug, M/T
TIGHTENING SPECIFICATIONS Plug 39 Nm (29 ft. lbs.)
Fill Plug, M/T
TIGHTENING SPECIFICATIONS Plug 44 Nm (33 ft. lbs.)
Oxygen Sensor
Torque 33 ft.lb
Plug Gap
Spark Plug Air Gap Standard 0.043 in (1.1 mm)
Service Limit 0.051 in (1.3 mm)
Torque
Spark Plug Torque 13 ft lb (18 Nm)
Steering Wheel
GENERAL SPECIFICATIONS Rotational Play [1] 0 - 10 mm (0 - 0.039 inch)
Starting Load [1,2] 29 N (3.0 kgf, 6.6 ft. lbs.)
Wheel Diameter 380 mm (15.0 inch)
Steering Wheel Bolt 38 N.m (3.9 kgf.m, 28 lbf.ft)
TIGHTENING SPECIFICATIONS Wheel Bolt 38 Nm (28 ft. lbs.)
[1] At steering wheel circumference.[2] Engine running.
Suspension
System Specifications
TORQUE SPECIFICATIONS Splash Guard Screws 4.9 Nm (48 ft. lbs.)
Upper Ball Joint Nut 39 - 47 Nm (29 - 35 ft. lbs.)
Lower Ball Joint Nut 69 - 78 Nm (51 - 58 ft. lbs.)
Radius Rod Ball Joint Nut 49 - 59 Nm (36 - 43 ft. lbs.)
Lower
TORQUE SPECIFICATIONS Castle Nut 69 - 78 Nm (51 - 58 ft. lbs.)
Upper
TORQUE SPECIFICATIONS Castle Nut 39 - 47 Nm (29 - 35 ft. lbs.)
Shock Absorber
TIGHTENING SPECIFICATIONS Top Flange Nuts 38 Nm (28 ft. lbs.)
Top Self-Locking Nuts 29 Nm (22 ft. lbs.)
Rear Bottom Bolt 64 Nm (47 ft. lbs.)
Axle Nut
TIGHTENING SPECIFICATIONS Front 245 Nm (181 ft. lbs.
Rear 181 Nm (134 ft. lbs.)
Throttle Body
Torque 16 ft.lb
Variable Valve Timing Solenoid
Torque 107 in.lb
Wheel Fastener
TORQUE SPECIFICATIONS Wheel Nut 108 Nm (80 ft. lbs.)
I hope this helps you guys out.
Old 03-13-2018, 02:36 PM
Honda-Fanatic32's Avatar
Default Re: Torque Specs For 5th Gen Preludes.
Do you have specs for a inner tire rod?
teamm_AP1
Suspension & Brakes
10-05-2009 05:27 PM
tjsker
07-25-2006 11:21 AM
Axle
01-15-2005 06:08 AM
02Civic*Si*
04-04-2004 10:48 AM
Todatyper
12-28-2001 02:37 PM
Quick Reply: Torque Specs For 5th Gen Preludes.
