throttle plate question
Old Apr 20, 2009 | 04:07 PM
nemesiskrp's Avatar
Default throttle plate question
I think I found my idle issue. first when your idling, is the plate completely closed? i think the plate is sticking or the cable spring is i don't know. I can move the lever for the throttle to the right about 20 thousands or so and the idle goes way down from about 1000 to 100. i am thinking it is a couple things, the throttle plate is not closing or opening where it is suppose to be at idle as if something was sticking, or the cable is to tight or to loose? anyone thoughts?
Old Apr 20, 2009 | 05:04 PM
117's Avatar
117
Default Re: throttle plate question
Do you have any slack in the cable?
Old Apr 20, 2009 | 06:03 PM
Hawkze_2.3's Avatar
Yes, it should be closed with no pressure on the gas pedal, but even a new throttle body will drop the idle a bit if you push on the plate when it's closed. Clean out the inside of the TB and adjust the idle screw and see where that gets you....
Old Apr 20, 2009 | 08:43 PM
nemesiskrp's Avatar
okay i found the prob, i adjusted the screw over a bit and it fixed it, it was just a little tight. now the idle is good and i now i can get full throttle, i also sprayed some carb cleaner. sweet
elnegro
Sep 13, 2018 06:35 PM
cdmef
Jul 3, 2011 06:03 AM
emooheo
Mar 23, 2007 02:34 PM
graphic
Oct 23, 2003 06:35 PM
Shft@9GSR
Nov 15, 2002 11:21 AM
