system in the trunk
Old Oct 8, 2009 | 05:13 AM
  #26
Rob97'SH's Avatar
Default Re: system in the trunk
I tried the 2 12s in the trunk and from my point of view my single 12 in a custom glass box(1.0cf) sounds better and I keep my trunk. Good luck trying to fit the box in the first place.
Old Oct 8, 2009 | 09:34 AM
  #27
kyx's Avatar
kyx
New User
if you can fit the box in the trunk with 12's you can do it. But gotta estimate your space and estimate what kind of box will fit.
Old Oct 9, 2009 | 06:55 AM
  #28
rjr162's Avatar
The issue is, the Prelude doesn't have a large trunk. A properly built ported box for two L7's is going to be huge.
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 3.25, 92.1
(Those are NOT including the port volumes, which will increase the overall size of the whole box)
That's 3.5 cubic feet of airspace within the box AT A MINIMUM for both subs, or 6.5 cubic feet for a max. Even at around 5 cubic feet it's going to be a large box. It *can* be done, but with the height of the rear deck, the box will have to be long and wide to try to get that airspace.
You could either switch to 10" subs, or go with a single 12". Even one 12" L7 in a properly built box with the port tuned correctly and a proper amp, it will be loud inside. Now granted you're going to get a good bit of rattling most likely.
Old Oct 10, 2009 | 10:22 AM
  #29
Daddy7's Avatar
Yeah I'm no longer getting 2 12" I because it will be very difficult. Im either going with 1 12" or 2 10". They will be DC Audio Lv4
Old Oct 10, 2009 | 10:36 AM
  #30
kornkid21792's Avatar
dude just get 2 alpine type r 10s those are bout the best subs ever imo
or get the alpine box is that is very small has a built in amp. and is the equivelant of 3 10s except u still have sooooooooo much space in the trunk becuz u dont need amps or anything you just hook it up power ground remote
its amazing if your trying to save space
Old Oct 11, 2009 | 06:57 AM
  #31
prion's Avatar
I had a single 12 in a 5.5 cubic foot ported enclosure in the trunk at one time. I had to build the box in two pieces and finish assembly in the trunk for it to fit. Tuned to 18 Hz, it was superb at reproducing near infrasonic frequencies.
Now I just run 4 10's on the rear deck in small sealed boxes so I can have my trunkspace. Car audio is always a compromise.
bad71chevy
May 19, 2013 09:39 PM
305PRC91
Jul 27, 2008 04:33 PM
thw_goalie
Audio / Security / Video
Aug 16, 2007 06:08 AM
crystalblue99lude
Jun 3, 2005 04:37 PM
Calvin Lai
Jun 7, 2001 01:19 PM
