Summer 4WS Problems
Ok, now that the temp is going up here, im having more and more problems with the 4WS. The 4WS coming on at start-up about 30-50% of the time now. Seems to be when the temp is above 85 degrees.
Other than the soldering fix, are there any temporary fixes any of you have found to work? How to reset ECU by turning steering wheel? How do i know if i need four wheel alignment? Woulkd this help? Right now, when the light is on, the rear wheels seem to at least lock in place (knockin on wood).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote"> Does it make sense that the problem is worse when its hot outside?</TD></TR></TABLE>
I will say that I am not surprised.
I have a spare 4WS ECU if you are looking for one. I resoldered it, it worked for a few months, then had issues again.
Actually yes, it does. It there are loose connections then they expand more when it's hot outside.
conductivity is better when it's cold.
depending on the code your 4ws is sending i think there is a recall, that honda should fix for free .. but do the solder fix first - worked for me.
i hope i don't get yelled at for this post but what is the "soldering fix"? i just put a new motor in my car and the 4ws light comes on sometimes, more often since it has been getting warmer. btw: i bought the car with a blown motor.
scroll down this page...
https://honda-tech.com/zerothread?id=886363&page=3
it will tell you how to fix it with photo's - i did the write-up - but it's based on knowledge gained from a ht member by the name of wstef.
let us know how it works for you
I forgot to mention, at speed, you can def tell the difference whem the rear wheels are locked. I am positive that there is more body roll when the rear wheels arent turning. I really cant imagine buying a non 4WS prelude after this.
Regal
13
Mar 20, 2008 12:49 AM
UK CIVIC B16A2
11
May 10, 2004 04:28 PM
Bang Easy
Feb 21, 2004 07:02 AM
