SPEEDOMETER NOT WORKING PLEASE HELP!!!!!!!!!!!
Old Aug 16, 2004 | 03:35 PM
vteckilla7's Avatar
Default SPEEDOMETER NOT WORKING PLEASE HELP!!!!!!!!!!!
After I finished my motor swap, I found out my speedometer was not working, car is also idling really low, and sometimes dies, I know my throttle cable needs to be adjusted ,could that be a reason for the low idle???.Also after driving the car for awhile the check engine light comes on, and fourth gear blinks green. Could someone please give me some info??? car is an automatic
Old Aug 16, 2004 | 05:47 PM
vteckilla7's Avatar
Default Re: SPEEDOMETER NOT WORKING PLEASE HELP!!!!!!!!!!! (vteckilla7)
any 1 have any info for me
Old Aug 16, 2004 | 06:06 PM
Hawkze_2.3's Avatar
Heh, I've been wrestling with the speedo problem for a while, and I finally took it out and found that one of the connectors had come loose and water got in there and rusted that connector so much that it broke off......So I'd say take off the VSS and check it.
A tight throttle cable would cause higher idle, but I don't think loose hurts anything but throttle response.
Check and see what number the code is.
Old Aug 16, 2004 | 06:13 PM
vteckilla7's Avatar
Default Re: SPEEDOMETER NOT WORKING PLEASE HELP!!!!!!!!!!! (Hawkze_2.3)
well I had some vaccume lines hooked up wrong so I hope that eliminated the idle problem, but we'll see tomorrow
busha61067
Feb 13, 2010 09:00 AM
Spence
Apr 24, 2006 08:15 PM
civicEXtreme
Jan 12, 2006 07:20 AM
Roy2377
Nov 9, 2004 10:41 PM
douboi
13
Oct 15, 2004 09:16 PM
