Let's talk about Spark Plugs
Old 07-22-2002, 09:46 AM
reefer_bob's Avatar
Default Let's talk about Spark Plugs
Specifically replacement ones. I have 26k on my car, and don't want to use the stock plugs for the full recommended service interval.
Well, after my initial sticker shock of Kragen wanting $19 each, and Pep Boys $25 Each. Carland Acura has them for $12.92 each. This is everyones favorite NGK PFR6G-13. Laser Tip Platinum. (B18C1 and C5 use the same stock plug correct?)
Through many of the other spark plug threads, some people like copper, some like platinum, some people change their plugs often, others don't. I want to change mine often, but I'm not sure if I'll be happy with a copper substitute. Any new storys about running the coppers as opposed to the Platinums? What is the proper NGK copper plug to use?
Thanks for any input.
Old 07-22-2002, 10:10 AM
sgT
sgT's Avatar
Default Re: Let's talk about Spark Plugs (reefer_bob)
gsr uses pfr6g-13
itr uses pfr6g-11
You can get BKR7EVX-11 for about 6 each i think
Old 07-22-2002, 11:15 AM
GraphiteAccord's Avatar
Default Re: Let's talk about Spark Plugs (sgT)
lord, where are you guys getting these things? i'm getting my NGK's (non plat's) for about 3$ each from the worse place ever, Autozone! i don't run plats cause they burn very hot...
Old 07-22-2002, 11:21 AM
sgT
sgT's Avatar
Default Re: Let's talk about Spark Plugs (GraphiteAccord)
tahts because we dont use the generic platinum.
I only use fine tip electrode plugs
Old 07-22-2002, 11:29 AM
98itR484's Avatar
i use the bosh 4227....1.99 each, change them every other oil change, dyno proven power on a 200+ NA car.
Old 07-22-2002, 11:43 AM
sgT
sgT's Avatar
Default Re: Let's talk about Spark Plugs (98itR484)
they dont work for me.
Old 07-22-2002, 11:49 AM
reefer_bob's Avatar
So, sgT, how often do you change your plugs, even though they're the fine 'laser' tip platinum? I figure 2 Years, 26k is about time for me...
Old 07-22-2002, 12:13 PM
sgT
sgT's Avatar
every 5k miles at most
Old 07-22-2002, 12:32 PM
reefer_bob's Avatar
Wow, You must spend a lot of money on Spark Plugs. But I guess, as you said in an earlier post, you don't wait till your brakes are on the backing pad before replacing them! And I can't say much, cause I change my synthetic oil every 3k...
pfork
06-22-2007 07:37 PM
patdemps
09-10-2003 11:33 AM
mattmw88
02-22-2002 07:54 AM
silvercivicsir
02-18-2002 02:36 AM
JDM R98
07-31-2001 07:23 PM
Quick Reply: Let's talk about Spark Plugs
