spark plug preference?
Old Jan 29, 2009 | 06:53 PM
  #26
Lovemy99Lude's Avatar
Default Re: spark plug preference?
I will def let you know how well they work. I'm going to be driving a lot this weekend here in KC. Going to have great weather, like 60's! Plan on taking a day trip up to the north side of town, so should get some cruising miles to see how the NGK's perform. I'll let you know in a couple days.
Old Jan 30, 2009 | 02:00 PM
  #27
MikeLuder's Avatar
Ha I live in KC. Where you going Cruising to? There isn't too many fun places to cruise around here! The coolest road I have found in this area, is on the other side of Lawrence. It's a small highway (k40) that goes from Lawrence to Topeka on the back side. It's filled with curves and twists, good scenery, and usually just enough of a stretch to drop into vtec. cheers. btw, the Iridiums are definitely good enough to get the job done. I'd say they are pretty equal to the Laser Platinums, just wont last as long as them.
Old Jan 30, 2009 | 03:35 PM
  #28
117's Avatar
117
Originally Posted by dk4ever
The Laser platinum's last longer, but also the have a purer burn. So thinking from a technical aspect. Once you get into the higher rpm's the v-power's will never perform as well or last as long as the Iridium's or the Laser platinum's.
Do you have any links for such spark plug tech?
Old Jan 30, 2009 | 06:38 PM
  #29
95greenlude's Avatar
+1. All jokes aside. The Laser platinum's last longer, but also the have a purer burn. So thinking from a technical aspect. Once you get into the higher rpm's the v-power's will never perform as well or last as long as the Iridium's or the Laser platinum's.
Look through the FI section and search "spark Plug"
almost everyone unanimously chooses the V-power plugs
Old Jan 31, 2009 | 03:46 PM
  #30
adam00's Avatar
i have bosch +2 platinum plugs and they work fine
Old Jan 31, 2009 | 04:03 PM
  #31
Targa250R's Avatar
be professional
Originally Posted by Lovemy99Lude
Looking to change out my current spark plugs. Anyone have a certain type of plug they like to use. I'm not sure which ones to get to improve gas mileage, if all possible.
There are only two brands of spark plugs that you should EVER use in a Honda:
- NGK
- Denso
You have a number of choices from those two brands: standard copper, platinum, iridium, etc. The only differences are price and longevity - the copper plugs are usually $2-3 each and should be changed every 30,000 miles, while the platinums and iridiums are usually $12-14 each and can go for 105,000 miles. Stick with the stock heat range unless you are using forced induction/nitrous/etc.
The factory plug for an H22A4 will be either an NGK platinum PZFR6F-11 or a Denso platinum PKJ20CR-L11.
Spark plugs will not improve fuel economy unless your old plugs were worn well past their service limit. Don't fall for the sucker marketing of any brand that claims power or efficiency gains over another brand or type of plug; it's all BS.
Old Jan 31, 2009 | 09:25 PM
  #32
Cool, another KC Luder! Lately I just been cruizing up and down Metcalf Ave. That seems to be where I se most of the tuners. I haven't ventured out of the city yet.
ZXiPoZ
May 3, 2012 09:25 AM
nickolas388
Oct 26, 2005 08:01 PM
Calean007
May 9, 2005 07:04 PM
LOSERboy
13
Aug 13, 2004 10:56 AM
