Replace Cat with drilled Straight Pipe
Old Dec 11, 2003 | 07:30 PM
Del_Slowest's Avatar
Default Replace Cat with drilled Straight Pipe
I don't want to get a new exhaust b/c all my money has been spent for x-mas. I have been thinking about cutting my cat out of the car and replacing it with a straight pipe which i'll drill holes into to help the backpressure. Do you think this will be okay? I have a OBD1 D16Z6
Old Dec 11, 2003 | 07:59 PM
Bailhatch's Avatar
Default Re: Replace Cat with drilled Straight Pipe (Del_Slowest)
cut holes to reduce back pressure? what are you talking about exactly, a perforated tube like inside a muffler or resonator?
Old Dec 11, 2003 | 08:15 PM
Default Re: Replace Cat with drilled Straight Pipe (Bailhatch)
Yes, drill some big 1 inch holes in it.
Old Dec 11, 2003 | 08:27 PM
matt_sb2000's Avatar
You might as well just run open downpipe.
Old Dec 12, 2003 | 02:59 AM
Default Re: Replace Cat with drilled Straight Pipe (matt_sb2000)
You really think it'll be just as loud? My main goal is just to make it look like it's hooked up since we have **** cops that like to check loud exhausts. Has nobody ever done this before?
Old Dec 12, 2003 | 05:32 AM
shermanyang's Avatar
drilling holes in your cat or test pipe will slow your car down...maybe even throw a CEL. this is cause it will interfer with the exhaust flow. it's like having a hole in your exhaust...
Old Dec 12, 2003 | 05:55 AM
Default Re: Replace Cat with drilled Straight Pipe (shermanyang)
I figured since i have a open downpipe right now and i don't throw any codes then why would it hurt it to free up some exhaust pressure by removing the cat and throwing in a drilled section of pipe. You really think it'll make the car slower? I thought it would actually help the turbo spool up faster but i could be wrong
Old Dec 12, 2003 | 05:59 AM
if you're gonna throw on a full exhaust with a test pipe, a drilled test pipe will interfer with the current of the exhaust flow. now if you're gonna just run a drilled test pipe and no exhaust...i don't think it'll do anything at all.
if you've ever had a hole in any part of your exhaust, you'll know what i'm talking about.
Old Dec 12, 2003 | 06:21 AM
RedTegLS's Avatar
If your running open exahust now you better check and make sure you even have a bulb in your check engine light spot. When you turn the car on does it come on and go back off?
Old Dec 12, 2003 | 08:17 AM
Bailhatch's Avatar
Default Re: Replace Cat with drilled Straight Pipe (RedTegLS)
He's OBD1 so why would any kind of exhaust modification after the O2 set a CEL? anwser - it woulden't. You can do anything you want after the o2, ECU won't know the diff. Sounds like a cutout might be a little cleaner setup but 1" holes will act the same way just with a little more turbulance
Old Dec 12, 2003 | 11:53 AM
Ahh, your right. Those E-cutouts are pretty sweet. I like the one mistabone made the best though with just the plate with the wingnuts. Looks like i have some welding to do, thanks for showing me the light
Old Dec 14, 2003 | 07:54 PM
Bailhatch's Avatar
Ya, good call on the old school style cutout. Thats what I'de get if I did one. Nothing to break and you could even make it 100% in your shop either from scratch or using a 2.5 or 3" exhaust flange with studs welded or pressed in. Make it and take pics....
VspecSiR
Oct 26, 2005 08:48 PM
T--Rex
Jul 31, 2004 02:05 PM
JDM00SI
Jul 19, 2004 10:36 PM
niceguy
Oct 13, 2002 05:47 PM
Fatty_1775
Aug 5, 2002 07:48 PM
