solid, quality, cost efficient build on an H
Old Dec 20, 2005 | 01:38 PM
972drcordex's Avatar
Default solid, quality, cost efficient build on an H
ok so my block on the h is on its way out and Im due for a rebuild. I dont want to spend to much money but at the same time I dont want to use cheap materials. So I was thinking oem bearings, eagle rods, je piston heads etc. What would you guys use if you were rebuilding your block but didnt want to go crazy exspensive. So just list out what you would go with from who and where would you buy it from?
Old Dec 20, 2005 | 02:27 PM
H23 Power's Avatar
Default Re: solid, quality, cost efficient build on an H (972drcordex)
what are the plans for the motor/power?
rods/forged pistons are overkill for a n/a motor. plus you will have to have the block re-sleeved to do forged pistons.
stock rods, (arp bolts if they make them) with type s pistons would be good for n/a.
Old Dec 20, 2005 | 02:41 PM
The_Sober's Avatar
Default Re: solid, quality, cost efficient build on an H (H23 Power)
you want cheap and reliable?
OEM, then leave it stock; or just do I/H/E easy as pi...
Old Dec 20, 2005 | 05:00 PM
flyrod's Avatar
Default Re: solid, quality, cost efficient build on an H (The_Sober)
Type S cams and oversize Type S pistons is not a bad way to go. These parts are getting cheaper these days, and should give you oem reliability.
Old Dec 20, 2005 | 07:35 PM
Default Re: solid, quality, cost efficient build on an H (flyrod)
I am not looking for any crazy power gains but some would be nice since I am rebuilding it and it would be stupid not to gain something from it. Where is the best place to purchase type s parts?
Old Dec 20, 2005 | 07:55 PM
CivicSiDriver02's Avatar
http://www.hmotorsonline.com sells type s pistons, cams, and even the euro-r intake manifold. I have had and heard nothing but good experiences with them. I ordered my H22 swap from them about a year and a half ago and it went smooth as butter and its still running like a top. The IM will run you 225+shipping, cams are 550 shipped, and the pistons are 200 shipped. The price I gave is for new oem jdm parts. These part coupled with an intake, good header, exhaust and some tunning should get you to around 200+ whp.
bzyq2001
Nov 17, 2007 03:25 PM
bzyq2001
Oct 2, 2007 06:37 PM
972drcordex
Dec 20, 2005 07:16 PM
HondaGuy02
12
Apr 17, 2004 09:47 PM
90da4dr
Feb 22, 2003 08:23 PM
