grounding problem....
Old Nov 24, 2006 | 09:43 AM
jinteg730's Avatar
Default grounding problem....
anyone know for sure where the ground is for the heat console... im blowing the fuse like crazy and its starting to get cold....... help me out please..... i cant figure out what the problem is. and on top of that i have a leak in my trunk somewhere and i have puddles in my trunk whenever it rains.... its the worst... help me out
Old Nov 24, 2006 | 12:27 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: grounding problem.... (jinteg730)
The leaks could either be from your drain tubes not being hooked up,
or water could be coming through where the taillights are.
If you take of the side interior panels, the drain tubes will be visible.
Old Nov 24, 2006 | 01:31 PM
Perfectionist's Avatar
If you're blowing fuses, the ground is not the problem. In fact, you've got one too many grounds. One, of course, being at the wrong part of the circuit. Look for chafed wires or backtrack any installs or mods you did recently before this became a problem.
Old Nov 24, 2006 | 02:30 PM
Nors's Avatar
Thats not true perfectionist. He could have a corroded ground that has excess resistance which is causeing the heater to draw to much current. Or he could have a short to ground before the load (heater). It all depends really, but I'd say if it blows after running a little and not immediatly when you turn it on then you probably have a bad ground with corrosion increasing the overall resistance of the circuit. Or like perfectionist also mentioned, a chaffed wire that sometimes shorts to ground when its moved a certian way. Check the ground first before you have to start tracing wires all the way back to the power source.
EDIT: Oops, got OHMs law mixed up. Forget the whole idea about corrosion that would cause low amps not high amps. Start looking for the broken/chafed wire. Sorry perfecionist, looks like your name isn't far off.
Old Nov 24, 2006 | 08:45 PM
jinteg730's Avatar
Default Re: (Nors)
if i switch a fuse.. it happens immediately when i start the car... so ur saying i should chase wires from my heater? where should i even start? thanks guys
Old Nov 25, 2006 | 05:42 AM
jinteg730's Avatar
Default Re: (jinteg730)
up
Old Nov 26, 2006 | 04:04 PM
jinteg730's Avatar
bump
Chronicsinners
Mar 4, 2005 08:23 AM
coldfiremx
Jan 14, 2004 05:37 PM
Elisa
Oct 16, 2003 03:58 PM
