shifting problems
Old Jan 26, 2003 | 05:20 PM
krnboixshawn's Avatar
Default shifting problems
when im at a complete stop and i try to put the gear into first, sometimes it gets stuck and i have to release the clutch and do it again. is this a normal thing with manual cars or is there something wrong with my clutch. i only have 23,000 miles on my car, is it time to replace my clutch? please help
Old Jan 26, 2003 | 07:49 PM
rokestah's Avatar
Default Re: shifting problems (krnboixshawn)
I doubt this is the case with yours, but I had that problem when my clutch master cylinder started going. It was really hard to get into first when I have stopped at a red light, for example. otherwise, try shifting to other gears then back to first. Thst is normal (well, sort of).
Old Jan 26, 2003 | 08:11 PM
el_Presidente's Avatar
that happens to me on occasion. it's annoying as ****. i just haven't gotten to fixin it yet, if that's possible. what i got into the habit of doing is when i'm at a stop and in neutral, i'll go to second and then shift to first, all w/o lifting the clutch. that usually takes care of it.
i would also like to know what the deal is with that.
Old Jan 26, 2003 | 08:49 PM
prelude1897's Avatar
I think it may be something that happens to alot of cars. My car does it, and so does my GF's prelude...
Old Jan 26, 2003 | 09:08 PM
stoopid215's Avatar
blip the throttle? usually works for me.. to shift into 1st.
Old Jan 27, 2003 | 12:15 PM
vtecfiendsh's Avatar
Default Re: shifting problems (stoopid215)
Yeah my 98 SH does that too, and so did my 91 CRX sometimes. I have a couple diff ways to getting it to go into gear. I do the thing where i blip the throttle, I also do the 2-1 shift. Other time i just let out on the clutch then push it back in and it seems to usually go. If not just touch the gas and it will
vtecfiendsh 98 SH
Old Jan 27, 2003 | 12:22 PM
DsITR's Avatar
Default Re: shifting problems (vtecfiendsh)
I drive a 97 SH and I have the same prob on occaision..
Like everyone else is saying, just give it a lil throttle and it pops right in..
I think its kind of ridiculous, I took my friend in a ride and this happened. He noticed I rev match alot when I drive (he is into drag racing, so I had to explain) and asked "you have to rev match from a stop??"
I am changing my clutch and flywheel right now..Im going to try running GM syncromesh MTF instead of Honda MTF an see if that helps at all..
Ill let you know..
Old Jan 28, 2003 | 09:45 AM
jdmDAxsi's Avatar
Default Re: shifting problems (dsludefosho)
i had problems gettin in reverse...sometimes it wont even go into gear...or when i do get it in..it pops out when i gas'd it...so i decided to change my transmission fluid...and the gears seem to go in alot better...
Old Jan 28, 2003 | 07:53 PM
stinger's Avatar
Default Re: shifting problems (vtecpreludeTT)
Mine wont allow you to go into first easily when its cold outside, summer was fine but its also a diff clutch too
hatchsi0485
Nov 21, 2005 06:13 AM
TnLude2000
Feb 27, 2005 02:32 PM
CrazyModGSR
Sep 7, 2004 03:53 AM
onyx00
Aug 20, 2004 11:34 PM
allmotorls95
Feb 26, 2003 02:44 PM
