shift linkage problem or master clutch cylinder
i finally decide to move the car after the swap was done...thing is it doesnt want to go into gear...when i try to put it in reverse it grinds...wont go into first either...anybody knows wut the problem is help plz
Re: shift linkage problem or master clutch cylinder (dumpedeg6)
i would say it sounds clutch related, does it go in gear when the car isnt running? also is it hydrolic clutch or cable? if hydrolic, try bleeding it again. more info is needed
Re: shift linkage problem or master clutch cylinder (CRXified)
hyro tranny....it can go into gear when the car is off...but if the car is on it wont go in...
