Rod Knock on 1997 H22A4 ~ HELP!
Old 07-07-2012, 10:53 PM
carkrayze's Avatar
Default Rod Knock on 1997 H22A4 ~ HELP!
Ok so I need to rebuild my bottom end on my 1997 Prelude SH.
I have a set of NPR Pistons/Rings, But I need to find an OEM full gasket set or atleast an OEM head gasket set, Good Set of bearings, and a new oil pump.
I searched for topics on this but all the links are expired or the companies are out of business. Im mainly concerned about the OEM gasket set.
I'm not trying to do a performance build on it, just stock and maybe some little things for reliability if there is any.
Please help, or point me to some posts with current informaton. Thanks!
Old 07-08-2012, 01:47 PM
carkrayze's Avatar
Default Re: Rod Knock on 1997 H22A4 ~ HELP!
Already tried hondapartsunlimited.com
and hondapartscheap.com
Niether have it.
Please someone help!
Old 07-08-2012, 02:14 PM
minilogoguy18's Avatar
Why don't you just go to your local dealer? Most online places seem cheaper but after shipping it usually comes out about the same.
Old 07-08-2012, 05:46 PM
carkrayze's Avatar
I work mon thru saturday 7-6. so they are closed before and after i get off work all week. im forced to do it online.
Old 07-10-2012, 12:21 AM
carkrayze's Avatar
BUMP!!!
Old 07-10-2012, 02:04 AM
1funryd's Avatar
If you want an OEM Gaskets, then check check if your local dealership sells parts online and order it that way.
Old 07-10-2012, 05:38 AM
97ludedude's Avatar
hondaautomotiveparts.com
Old 07-10-2012, 12:05 PM
carkrayze's Avatar
OK thanks
Old 07-10-2012, 03:11 PM
TheJGB3's Avatar
15100-P5M-305 SET PUMP ASSY., OIL $191.26
http://www.hondapartsnow.com/genuine...0-P5M-305.html
12251-P5M-004 GASKET, CYLINDER HEAD $57.25
http://www.hondapartsnow.com/genuine...1-P5M-004.html
12030-P13-000 GASKET SET, HEAD COVER $40.57 (includes vc gasket, sparkplug tube seals, and new grommets)
http://www.hondapartsnow.com/genuine...0-P13-000.html
15825-P13-005 FILTER ASSY., SPOOL VALVE $13.65 (VTEC solenoid gasket)
http://www.hondapartsnow.com/genuine...5-P13-005.html
12513-P30-000 RUBBER, CYLINDER HEAD SEAL $5.24 (cam seal - intake cam trans side)
http://www.hondapartsnow.com/genuine...3-P30-000.html
12210-PZ1-004 SEAL A, VALVE STEM (NOK) $1.08 (intake valve stem seal)
http://www.hondapartsnow.com/genuine...0-PZ1-004.html
12211-PZ1-004 SEAL B, VALVE STEM (NOK) $1.08 (exhaust valve stem seal)
http://www.hondapartsnow.com/genuine...1-PZ1-004.html
Old 07-12-2012, 12:37 PM
carkrayze's Avatar
thanks man! have you heard of beck arnley gasket sets? ive heard they use an oem head gasket??
Old 07-19-2012, 12:59 AM
carkrayze's Avatar
bump
ThatGinjaDude
01-03-2017 08:22 PM
LeeMajors19082
09-18-2015 03:59 AM
lilrobie69
01-30-2013 06:16 AM
forcedaccord95
04-27-2005 06:29 AM
SHhh__VTEC
01-10-2004 12:12 AM
Quick Reply: Rod Knock on 1997 H22A4 ~ HELP!
