piston to wall clearance question.
Old Aug 14, 2009 | 08:57 PM
slambedcivic's Avatar
Default piston to wall clearance question.
.0045 safe on a turbo engine?
I dont need any other questions. Just wondering.
Old Aug 14, 2009 | 11:07 PM
jdm602's Avatar
Default Re: piston to wall clearance question.
yes thats safe somewhat depending on the power goal in mind.
Old Aug 15, 2009 | 01:20 AM
B20luda's Avatar
what brand of pistons? coated?
Old Aug 15, 2009 | 05:01 AM
Boosted_B_Series's Avatar
Yes that's real safe and will protect your pistons from seizing during expansion.
I am running 5 thousands PWC, Manley pistons, GE Sleeves. Its quiet on cold start up, I was expecting some noise.
'Build it loose only you will know, build it tight everyone will know'
Old Aug 15, 2009 | 05:08 AM
Bailhatch's Avatar
It will also wear out faster than 35. The actual number depends on your bore size and the type of aluminum the pistons are made out of. Every piston manufacturer has guidelines and can tell you what a good PTW is for your application.
Old Aug 15, 2009 | 08:35 AM
narfdanarf's Avatar
depends on the setup. My motor is .005, best friends basic setup is .004.
Old Aug 16, 2009 | 07:53 PM
CP pistons. they call for .003 PTW. Im @ .0045. This bore is fresh from the machine shop. Im a little bit upset about this. Stock sleeves. Power goals are roughly 400ish w/ 10.5:1.
Old Aug 16, 2009 | 08:12 PM
B20luda's Avatar
thats a little big for only 400whp .003-.0035 would have been fine...
Old Aug 16, 2009 | 08:19 PM
narfdanarf's Avatar
Most CP's I've seen call for .0035, but regardless .0045 isn't too huge, especially for a stock sleeve motor with 10.5:1 compression.
Old Aug 16, 2009 | 09:29 PM
LastGenEK's Avatar
I think im at .0025
thats what the Wisco sheet had for hone specs
runs good!
Old Aug 16, 2009 | 09:36 PM
jdm602's Avatar
damn 0.0025? seems a little to tight to me. oem stock cast pistons i think are like 0.002. hah.
Old Aug 17, 2009 | 05:47 AM
blackeg's Avatar
im going .0035 with my cp's at about 450hp.
.0045 is a lil big but its not going to make your motor blow up or anything. side effects will likely be a lil slap till it warms up and it wil wear the hone a lil faster due to more contact with the cyl walls. so maybe instead of 60k miles you'll get 55k miles out of it...
just think about all the people out there with vitara builds that have like .006 ptw and are making good power and going fast at the track
Old Aug 17, 2009 | 12:47 PM
good call and surely noted. I think im gonna go with it instead of bitching about it to the machine shop. I figured when they measured the skirts to make sure they were dead nuts at 3.206 and CP called for a bore of 3.209 they would have done it.... who knew?
the.hamburglar
Mar 6, 2007 10:03 AM
99blackvti
Sep 7, 2005 01:46 PM
mz3bo
Jun 18, 2004 06:34 PM
swlabhot
May 20, 2004 01:44 PM
Benny Z
Dec 20, 2002 03:35 AM
