quick ? about ATTS
Old Jun 9, 2001 | 12:24 PM
spyder's Avatar
New User
Default quick ? about ATTS
Okay, I just want to know WHAT exactly ATTS is. I know it helps handling and that it doesn't get along well (or at all) with a turbo, but what is it and how does it work?
Old Jun 9, 2001 | 05:27 PM
Lewd Lude's Avatar
Default Re: quick ? about ATTS (spyder)
why dont you go to hondaprelude.com and find out
Old Jun 9, 2001 | 05:47 PM
spyder's Avatar
New User
Default Re: quick ? about ATTS (Lewd Lude)
In the time you wasting writing a useless post you could have given me the info I was after...
Old Jun 9, 2001 | 06:05 PM
jacques's Avatar
Don't mind Lewd Lude...you know how those Aussies are .
Anywhoo, ATTS stands for Active Torque Transfer System. In essence, when you go through a turn, the outer wheel increases torque to compensate for the inside wheel, giving the car a more neutral balance. It's not something you can hear, but for SH owners like myself, you can feel the outer wheel on turns, especially at high speeds. If applied correctly, you can carve corners with ease .
ATTS tends to deactivate if there's too much power to the wheels...I think 250 hp (at the crank) is the max. So, turbos might not go well with the SH, though some people have them on their Preludes anyway. That's why I like the Jackson Racing Supercharger .
[Modified by jacques, 9:11 PM 6/9/2001]
Old Jun 9, 2001 | 07:04 PM
spyder's Avatar
New User
Default Re: quick ? about ATTS (jacques)
Thanks man, you rock! That is exactly what I wanted to know!
Old Jun 10, 2001 | 02:18 AM
Lewd Lude's Avatar
That hurts Sarino
Old Jun 10, 2001 | 06:29 AM
apexii's Avatar
You're OK with me Spyder
Old Jun 11, 2001 | 11:09 AM
23109VC's Avatar
Default Re: quick ? about ATTS (apexii)
ATTS kicks ***. If you drive a Prelude SH and drive it HARD, you WILL feel it kick in. It's hard to describe but it feels like the car is being "pulled" around the turn. You have to learn how to drive with it. It actually drives better if you drive hard through a turn, and if it gets close to the edge/limit, and you lift off the gas, ATTS is no longer working so it gets worse.. usually better to just hold the throttle constant and ride it out.
Old Jun 11, 2001 | 04:10 PM
jacques's Avatar
Default Re: quick ? about ATTS (23109VC)
I should've done that when I was drifting, going around a large turn at the autocross. Even though it was cool that the car drifted, it hurt my time. I should've kept my foot on the pedal, instead of letting off the gas, and I probably would've gotten out of my drift sooner.
Old Jun 11, 2001 | 10:12 PM
Jarrad_r6's Avatar
New User
The beauty of ATTS is that if you get into a turn to hot and you let off the throttle the car oversteers, you get into a turn to hot and you stay on it, the car oversteers. Atleast you know what the cars is gunna do!
I love ATTS now that I am used to it. There is no denying that the car handles WAY better with ATTS than without. It truely gives the prelude the best of both worlds, sometimes it acts like a front wheel drive other times it acts like a rear.
AttS will also activate when the car is decelerating, ie you let off the throttle in a turn and it will slow down the inside front tire causing the car to rotate around that tire, do this wrong and you wil find the car pointing the wrong way as I did last time I went autocrossing.
J
ltran82
Honda S2000
Oct 25, 2007 10:51 AM
vinuneuro
Jun 29, 2006 10:40 PM
5thGenCivicKid
Mar 14, 2005 02:44 PM
Tad
Mar 29, 2004 05:59 AM
JustChou
Jul 5, 2002 03:26 AM
