question: "how to take tps off of the h22 tb"
Old 05-01-2006, 07:23 PM
hulk_22's Avatar
Default question: "how to take tps off of the h22 tb"
i have the 93' h22a obd1 tb and don't know how to take the tps off? do i have to drill, or is therea special tool for it?
Old 05-01-2006, 07:52 PM
i_kick_turtles's Avatar
Default Re: question: "how to take tps off of the h22 tb" (hulk_22)
Yes,you have to drill, and then replace the rivets with hex screws when you put it back together.
Old 05-01-2006, 09:47 PM
hulk_22's Avatar
cool
Old 05-01-2006, 10:49 PM
AznBlueBoy's Avatar
Default Re: (hulk_22)
the way i did it is use a saw and cut it a bit and then just used a flathead and it came off like a normal screw
this way you can reuse those bolts
Old 05-02-2006, 02:15 PM
shutta's Avatar
F*** hex screws, just use a bolt.. makes everything soo much easier. akso if you have a jdm h22 it will have torx screws but if you find the right size allen wrench, that will work. that's what I did and I didn't need ot take off teh throttle body. i think they are M6 or m7 threads
Old 05-02-2006, 03:20 PM
Skidtron89's Avatar
HAHA dork! come on man
Old 05-14-2006, 02:23 PM
boosted96midorihatch's Avatar
no no no no no no no no no you dont have to do any of that crap just get the throttle body and turn it tps side up and get a small sharp flat head and a hammer and tap a dent in it going counterclockwise then keep tapping it then jus unscrew by hand easy easy easy
Modified by boosted96midorihatch at 10:31 PM 5/14/2006
Old 05-14-2006, 05:17 PM
mgags7's Avatar
^^that will work, i drilled mine out, whatever floats your boat i guess....
hamadiscool
01-15-2007 08:37 AM
hulk_22
07-12-2006 11:48 PM
r1de4life
01-11-2006 11:19 PM
Trbospnkr
03-03-2004 01:47 AM
Vp Special K
04-08-2003 07:58 PM
Quick Reply: question: "how to take tps off of the h22 tb"
