prelude h2b trans?
Old 06-24-2007, 09:26 AM
GoldLudeRay's Avatar
Default prelude h2b trans?
why dont i read about preludes swapping too the b-series trans
like all the civics using the h2b kit
i need a new a trans and i am wondering y it doesnt fit as well as it does in a civic?
is the mount different on the lude or is linkage and axels a problem, it would be nice too have more transmission choices,
also what clutch do u guys think will be good for my set up?
1992 si
h22a motor
camp1320 header
full mandrell exhaust
adj cam gears
milled and ported head
ported im and tb
sri
75 wet shot n20
tuned on a vafc
i will be running both slicks and street tires
Old 06-24-2007, 09:32 AM
WhiteBB2's Avatar
Default Re: prelude h2b trans? (GoldLudeRay)
the H2B plate lets the tranny mount to the car and mount to the engine. doesnt fit the opposite way unfortunately!
Old 06-24-2007, 09:33 AM
WhiteBB2's Avatar
Default Re: prelude h2b trans? (WhiteBB2)
let me try and make that a little clear
H2B allows the B series tranny bolt to the car and the H series engine in a CIVIC/TEG, wont work on a prelude with a B series tranny.
Old 06-24-2007, 11:49 AM
TylerC161's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 &raquo;</TD></TR><TR><TD CLASS="quote">let me try and make that a little clear
H2B allows the B series tranny bolt to the car and the H series engine in a CIVIC/TEG, no one has done it yet on a prelude with a B series tranny.</TD></TR></TABLE>
fixed
Old 06-24-2007, 02:27 PM
somebody needs too try the h2b kit on a prelude
Old 06-24-2007, 02:37 PM
petern101's Avatar
Default Re: (GoldLudeRay)
someone needs to tell me why a b series tranny is so beneficial to preludes.....
i mean seriously, the only thing i can see is the aftermarket parts (which most luders don't even utilize)
i guess the only benefit is availibity. but just bite down and buy a h22 tranny.
Old 06-25-2007, 08:36 PM
WhiteBB2's Avatar
Default Re: (petern101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">someone needs to tell me why a b series tranny is so beneficial to preludes.....
i guess the only benefit is availibity. but just bite down and buy a h22 tranny. </TD></TR></TABLE>
the dependability of the b series tranny seems to be better than the H22 tranny. and the gearing would be amazing IMO
Old 06-26-2007, 09:08 PM
petern101's Avatar
Default Re: (WhiteBB2)
the dependability of the b series tranny seems to be better than the H22 tranny. and the gearing would be amazing IMO</TD></TR></TABLE>
i haven't really seen that many h-series trannies go. but that could be debatable.
gearing = solved with aftermarket final drive. the only thing with that is if you add more power, you want longer gears. which i think the h23 trans does fine.
Old 06-26-2007, 09:51 PM
mattsnooz's Avatar
exactly, h23 tranny all the way
Old 06-26-2007, 10:04 PM
Hawkze_2.3's Avatar
I can see the benefit of Bisimoto's H2D conversion as the D tranny is smaller, lighter and proven tough, but I agree the B tranny probably isn't worth it.
Old 06-27-2007, 06:16 AM
NirVTEC's Avatar
Default Re: (Hawkze_2.3)
I don't think gears/reliability are a big reason for the decision.....
Placement and shift rods mixed with axle angle.....
Throw a 4.6-4.7FD at the H series and let the fun begin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I can see the benefit of Bisimoto's H2D conversion as the D tranny is smaller, lighter and proven tough, but I agree the B tranny probably isn't worth it.</TD></TR></TABLE>
Wouldn't BISI's be an F2D? lol
Old 06-27-2007, 08:35 AM
Hawkze_2.3's Avatar
Default Re: (:=:NirVTEC:=:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :=:NirVTEC:=: &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't BISI's be an F2D? lol </TD></TR></TABLE>
Haha, true true. I still wouldn't mind attempting that...I already have a flexible clutch line, so as long as there are hydro D-trannies it seems like all I would need to do is sort out the tranny mount and driveshafts. Oh well, daydreams...
Old 06-27-2007, 08:47 AM
so does the d series tranny fit in a lude chassie?
Old 06-27-2007, 08:54 AM
kulrevon's Avatar
I think the hardest part would be getting the shift rods to work correctly and not interfere with the exhaust.
Old 06-27-2007, 09:02 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldLudeRay &raquo;</TD></TR><TR><TD CLASS="quote">so does the d series tranny fit in a lude chassie?</TD></TR></TABLE>
Considering it's smaller than an H-tranny and our giant engine bays, I'm sure it will.
Old 06-27-2007, 11:09 AM
NirVTEC's Avatar
Considering it's smaller than an H-tranny and our giant engine bays, I'm sure it will.</TD></TR></TABLE>
If memory serves....The best Hydro D series gears are like an Accord F series trans. Ratios are poop. Gear swaps would be a must.....Might be real good for a Turbo car.
Old 06-27-2007, 11:41 AM
so were still thinkin a h22 trans will be the best for my set-up
Old 06-27-2007, 11:49 AM
P13_mein's Avatar
Default Re:
its the final drive and that 2nd gear on the type-R and B16 transmission that make the H2B so successful, coupled with the fact that the ideal geometry is retained.
92-96 H series transmissions actually have shorter first gears than the b series transmissions and in some instances 3rd 4th and 5th.
the h series transmission transmission being inferior is a myth.
what should be attempted is the transmission from a DA Gsr which is cable operated and have a favourable final drive & 2nd gear
a B series transmission in a prelude chassis is impractical. plus chipping away your block, having whomever is doing your engine mount first laugh at you (to your face) and then having them fabricate something costly and purely experimental, is purely up to whomever wants to try it.
Old 06-28-2007, 08:08 AM
NirVTEC's Avatar
Default Re: Re: (P13_mein)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein &raquo;</TD></TR><TR><TD CLASS="quote">its the final drive and that 2nd gear on the type-R and B16 transmission that make the H2B so successful, coupled with the fact that the ideal geometry is retained.
Amen to that.
People seem to bash the H trans only when not used in a Prelude/Accord chassis. Coincidence? No. The 1st guy I ever talked with in person years and years ago with an H22 in an EK complained about not being able to shift above 8000 or so. Purely the Cable in a Civic problem. A pack of zip ties and the Bisi trick and he was all good. 2 zip ties every 6" on the cables.
I personally want to swap an H22 into my Civic in the future and would go H2B all the way and it has nothing to do with my thoughts concerning the internals of an H trans. Placement-Axle angle are the key.
In 2001 L'Natural was running 10's N/A with a stock H trans and had the similar shifting problems.
MIDNIGHTTUNER
11-01-2014 02:27 PM
99cpevtec
02-01-2008 08:35 AM
98TEG2NV
04-18-2007 04:59 PM
slammed95lude
04-17-2007 03:22 PM
ismkv8s
02-22-2006 08:25 AM
Quick Reply: prelude h2b trans?
