Tech question
Old Dec 29, 2013 | 12:24 PM
1native's Avatar
Default Tech question
I have an 96 accord . I have an built head and an h22a block I want to use I also have the step down harness . For the ecu . Will this work in the car .i know there will be some sensor plugs not used .
1native's Avatar
Default Re: Tech question
I may not be explaining it correctly .
Old Dec 29, 2013 | 02:24 PM
ej7attack's Avatar
you have obd2 car with a motor you probably want to run obd1 so you will need an obd conversion harness.
Old Dec 29, 2013 | 04:14 PM
1native's Avatar
Yes I have an obd1 motor and chipped p28 and an obd2 car .i do have an obd 2 to 1 harness .am I gonna run Any codes
Old Dec 29, 2013 | 07:23 PM
MAD_MIKE's Avatar
MM Gruppe B
If you have the correctly chipped P28, correct conversion harness(with modifications for use of H22 in Accord), and all the sensors hooked up you should have no problems.
brownsEF
Aug 4, 2021 08:27 PM
Etorres325
Feb 5, 2010 09:21 PM
Wonk Unit
Feb 11, 2007 10:26 AM
bh2285
May 29, 2004 08:05 PM
HYREV2NR
Jul 27, 2003 04:28 AM
