Not Hitting VTEC, Please help!
Old Sep 24, 2003 | 05:17 PM
Import RP's Avatar
Default Not Hitting VTEC, Please help!
Alright, I have 4th gen prelude with an H22A1 motor. I am having two problems. If anyone can be of any help, that would be GREAT!
1) The speedo isn't working and it throws the speedo engine code.
2) Not hitting vtec and hitting the rev limiter at 6.5k rpm's.
I am pretty sure those two problems are unrelated. VTEC and normal engine rev limiting were working after the speedo broke. I am pretty sure I know how to fix the speedo sensor. But what about the VTEC, low rev problem??? What could possibly be wrong? Any opinions would be awesome!!
Thanks in advance,
Jeff
Old Sep 24, 2003 | 05:28 PM
BoosterSH's Avatar
Default Re: Not Hitting VTEC, Please help! (Pyrochaos38)
I know VTEC on H22s will delay or sometimes not even kick in if your oil pressure is too low. Check you oil to see if you have enough. The speedo is problably the sensor. Have you taken out your gauge face lately? Messed with the computer?
Old Sep 24, 2003 | 06:09 PM
Import RP's Avatar
Default Re: Not Hitting VTEC, Please help! (Project1320)
Oil is good, the speedo is assuredly the sensor. I know how to fix that. Its the vtec not kicking in that is relaly confusing me! Anyone else?
Old Sep 24, 2003 | 06:16 PM
fizzbob7's Avatar
as always, triple check your wiring and make sure that there are no other codes....it has to be up to normal operating temp also...until it's been running a few minutes, it won't hit vtec.....it's probably wiring....u using the USDM p13?
Old Sep 24, 2003 | 06:26 PM
Import RP's Avatar
Default Re: Not Hitting VTEC, Please help! (fizzbob7)
Yeah, but I haven't changed anything... Why would the wire randomly go bad?
Thanks for the input guys,
Jeff
Old Sep 24, 2003 | 06:33 PM
4bidden's Avatar
Did the VTEC problem correspond to the speedo code?
Old Sep 24, 2003 | 06:37 PM
Import RP's Avatar
Default Re: Not Hitting VTEC, Please help! (4bidden)
Nope, it happened about 3-4 days after the speedo was already broken... Any ideas? I wan get this fixed.
Thanks All!!
Old Sep 24, 2003 | 06:49 PM
98baselude's Avatar
make sure the engine is warmed up and then try to hit vtec. if the car is cold, vtec won't engage and redline will go down to 6500 rpm's. for the speedo problem, check the wiring. that's all i can think of.
Old Sep 24, 2003 | 07:21 PM
Import RP's Avatar
Default Re: (98baselude)
Thanks for the info, but even after having been running for an hour it sitll does it
Any more ideas?
Old Sep 24, 2003 | 08:03 PM
Cottonwoodz's Avatar
Default Re: (Pyrochaos38)
Its got to be the speed senser.. Vtec will only work if the ECU sees that the car is going faster then 19 MPH.. And if the senser is not working, the ECU thinks your not moving..
Old Sep 24, 2003 | 08:18 PM
Import RP's Avatar
Default Re: (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">Its got to be the speed senser.. Vtec will only work if the ECU sees that the car is going faster then 19 MPH.. And if the senser is not working, the ECU thinks your not moving..</TD></TR></TABLE>
You are sure about that?? So anyone know what I should do? Get a new speed sensor from Honda? Thanks for all the great help guys!
-Jeff
Old Sep 24, 2003 | 10:37 PM
Matgallis's Avatar
speed sensors aren't cheap. $210 for a new one in my legend from the dealer.
Old Sep 25, 2003 | 01:19 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pyrochaos38 &raquo;</TD></TR><TR><TD CLASS="quote">
-Jeff</TD></TR></TABLE>
yes it's in the helms.
4th gen conditions:
1. Engine Speed 4,900 rpm or higher
2. Vehicle Speed 19mph or faster
3. Engine Coolant 140F or higher
Old Sep 25, 2003 | 01:24 AM
safe driver's Avatar
try another ecu...?
Old Sep 25, 2003 | 05:12 AM
caliriptide's Avatar
Yes! WE ARE 100% SURE!!!
I had the same **** happen to me a week ago!!!
https://honda-tech.com/zerothread?id=620738
I used JB WELD AND SONIC WELD. Sounds Gettio But so far so good
Vtec will not work if you speedo doesn't.
Old Sep 25, 2003 | 01:55 PM
Mike95lude's Avatar
Default Re: (caliriptide)
Sweet, I'll give it a try this weekend! Thank you all so much for the help!!
-Jeff
Old Sep 25, 2003 | 06:25 PM
Dynamo Hulks's Avatar
I had exactly the same problem on mine. I had taken it to the honda dealer to have a new distributer fitted. While it was there they topped up my oil but used a mineral oil. The motor had fully synthetic in it. After a couple of days, the Vtec would not cut in and the motor would rev out to the limiter. I drained the oil used engine flush, fitted a new filter, refilled with good fully synth. The VTEC is now functioning correctly. I think the main thing about the VTEC is the oil as it is activated hydraulically. Hope you get it sorted.
Old Sep 25, 2003 | 06:58 PM
Jeff33S's Avatar
Yea fix the speed sensor then see if your vtec still isnt working.... As I always tell my friends when I'm working on their cars... One thing at a time......
-Jeff-
stehigs321
15
Mar 1, 2019 05:16 PM
kaboom954
Feb 25, 2010 03:23 PM
CTR_B
Mar 20, 2008 10:21 PM
Import RP
Sep 24, 2003 11:21 PM
Hondasaurs
May 9, 2003 08:51 PM
