Good for nitrous?
Old Sep 30, 2003 | 05:24 PM
94EGproject's Avatar
Default Good for nitrous?
I did a compression test on my d16z6 last nite and everything looked good. 200, 190,200, and 190. The engine has about 80k on it and pulls hard. I want to first run the nitrous express stage one kit with heater and purge on a 50 shot with jus colder plugs. then once i get a fpr, fuel pump, and ignition and timing control i want to run a 75 shot. Am i good for this or what? Any info would be sweet. thanx.
Old Sep 30, 2003 | 06:58 PM
mntdewred's Avatar
I have a D16Y8 with 85k miles on it. Compression numbers were 200 across the board. I am running a 75 shot of ZEX with retarded timing (according to ZEX sheet) and colder plugs (NGK-6097 from SummitRacing). I have stock FPR and Fuel Pump. I have had the kit since June 2003 and I am on my 7th bottle. Car/Motor is still in excellent condition.
Old Sep 30, 2003 | 07:11 PM
Default Re: (mntdewred)
i'm guessin u have some timing control for this or are u jus running the same daily? if so how does ur car run off the bottle?
Old Sep 30, 2003 | 07:40 PM
97hb's Avatar
Default Re: Good for nitrous? (94EGproject)
Make sure the clutch can handle it. I have colder plugs, fuel pump, and clutch. I run the 55 shot most of the time, 75 at the track. Never pulled timing, just run some high octane unleaded and was fine. Motor still running strong after 50k of straight abuse
nitroaccord105
Jul 18, 2007 12:32 PM
DA9kid
Jan 1, 2007 04:50 PM
tmekjian
Jun 11, 2003 11:35 AM
NAcivicEK
Apr 29, 2003 04:09 PM
integra2ner
Jan 6, 2003 09:54 PM
