RC Engineering Injector problem
Old Feb 6, 2004 | 03:43 PM
RaCk's Avatar
Default RC Engineering Injector problem
im just finished mounting my AEM fuel rail, fuel pressure regulator and RC engineering 440cc injectors. But the injectors will not pass fuel. They have 12v each, enough fuel in rail. Fuel pressure lies on 46psi. Wich should be optimal.
They also have the right resistance. 12 ohm.
Any suggestions?
Modified by RaCk at 2:37 PM 2/7/2004
Old Feb 7, 2004 | 05:24 AM
RaCk's Avatar
Default Re: RC Engineering Injector problem (RaCk)
*bump*
Old Feb 9, 2004 | 06:08 PM
RaCk's Avatar
I found this. Think it could help. Going to try it tomorrow.
Old Feb 9, 2004 | 09:45 PM
hondatim's Avatar
are you sure you have ECU signal on injector grounds. the ECU controls grounds of each injector in order to fire injectors. best bet is to install a noid light on injector connector and have someone crank engine while observing light to make sure it blinks. If it does not, may have harness disconnected somewhere or for some reason, ECU not supplying ground to injectors.
does engine start?
if not, how do you plan to perform test that you posted earlier?
BTW that test is for setting base ignition timing of engine, nothing to do with injectors.
Old Feb 10, 2004 | 07:39 AM
RaCk's Avatar
Default Re: RC Engineering Injector problem (hondatim)
i testet the injectors with an voltmeter.
The engine does not start.
Old Feb 10, 2004 | 05:36 PM
hondatim's Avatar
right, you tested the injectors with voltmeter. What I meant is that you now need to test for ground signal from ECU to injectors. not injectors themselves. this is where a noid light would be useful.
Let me know if you need any more help...
Old Feb 10, 2004 | 06:10 PM
RaCk's Avatar
i also testet the injector plugs.
wburke69
Aug 9, 2010 09:19 AM
shreddinryguy
Jun 26, 2005 01:28 PM
turboxsi
Apr 17, 2005 04:15 PM
Que_Lude
Dec 24, 2002 06:34 AM
