misshifted...
misshifted...
Damn. I shifted from the bottom of third(7200 rpm's) into second instead of 4th. Now major power loss. Idle is fine and I 'm not misfiring. I took the valve cover off and snaped all the springs they all popped back fine. checked valve clearances and they are ok too. But when I nail it from a standing start it feels like there is no VTEC. I can rev all the way to 7200 rpm's but when I shift i fall back to 4000 rpm's. Same thing happens in 2nd gear. Shift and fall to 4000 rpm's. In 3rd gear all is slightly norma.l Car pulls and when I shift I fall to around 5200 but still not as much pull as before. What do y'all think. Tranny??(hopefully) Open to any other tests I should perform I have full shop access
Re: misshifted... (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">You didn't misshift, you MONEYshifted.
Good luck with the rebuild. </TD></TR></TABLE>
Hahahah. Yea most definitly bent valves.
Re: (twistedbydezign)
do a compression and/or leakdown test. that will help you determine if valves are bent without taking the head off. It could have been a lot worse though...
Re: misshifted... (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy »</TD></TR><TR><TD CLASS="quote">hrmm, i wonder how many bent valves he has.</TD></TR></TABLE>
I would say all 8 exhaust valves.
I know of at least 2 other Prelude owners and myself who mis-shifted the same way. And all of us had bent all of the exhaust valves. Intake valves were fine though.
Re: misshifted... (vwong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vwong »</TD></TR><TR><TD CLASS="quote">I would say all 8 exhaust valves.
I know of at least 2 other Prelude owners and myself who mis-shifted the same way. And all of us had bent all of the exhaust valves. Intake valves were fine though.</TD></TR></TABLE>
lol, there have been pictures of worse than 8 valves..i remember someone on here had 15 valves that bent. :\
Re: misshifted... (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod »</TD></TR><TR><TD CLASS="quote">do a compression and/or leakdown test. that will help you determine if valves are bent without taking the head off. It could have been a lot worse though...
What am I looking for with a compression test??(it's easiest and the quickest so I'll do that first)
lol, there have been pictures of worse than 8 valves..i remember someone on here had 15 valves that bent. :\</TD></TR></TABLE>
Since I don't frequent this board, I haven't seen the pic. But 15 bent valves? That gotta sucks.
So I finally got around to compression test. Readings are: 200,190,185,210.
Look ok to me. Does it indicate any problems to any of you. By the way the car IDLES fine and I have no backfiring or missing occuring. Y'all still think it's the valves??
Damn bro it does sound as if you bet valves,
A compression test will tell you in what or how many cylinders..
ive done that once, got away with a blown Vtec pressure switch!!!
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">So I finally got around to compression test. Readings are: 200,190,185,210.
185 Is a little low, but now too bad, may have a slightly bent valve,
is your check engine light on?
