Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Prelude (https://honda-tech.com/forums/honda-prelude-4/)
-   -   misshifted... (https://honda-tech.com/forums/honda-prelude-4/misshifted-1257589/)
DCFIVER 05-25-2005 01:18 PM
misshifted...
Damn. I shifted from the bottom of third(7200 rpm's) into second instead of 4th. Now major power loss. Idle is fine and I 'm not misfiring. I took the valve cover off and snaped all the springs they all popped back fine. checked valve clearances and they are ok too. But when I nail it from a standing start it feels like there is no VTEC. I can rev all the way to 7200 rpm's but when I shift i fall back to 4000 rpm's. Same thing happens in 2nd gear. Shift and fall to 4000 rpm's. In 3rd gear all is slightly norma.l Car pulls and when I shift I fall to around 5200 but still not as much pull as before. What do y'all think. Tranny??(hopefully) Open to any other tests I should perform I have full shop access
prelittlelude 05-25-2005 01:19 PM
Re: misshifted... (cb7-R)
do a compression test
i bet you bent valves, sorry to hear it man!
AndyD 05-25-2005 01:23 PM
You didn't misshift, you MONEYshifted. https://honda-tech.com/forums/images/smilies/emsad.gif
Good luck with the rebuild. https://honda-tech.com/forums/images...es/emsmile.gif
prylwd 05-25-2005 06:06 PM
Re: misshifted... (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">You didn't misshift, you MONEYshifted. https://honda-tech.com/forums/images/smilies/emsad.gif
Good luck with the rebuild. https://honda-tech.com/forums/images...es/emsmile.gif </TD></TR></TABLE>
Hahahah. Yea most definitly bent valves.
high_revs 05-25-2005 06:58 PM
bent valves my friend..
97lude 05-25-2005 07:00 PM
bent valves http://images.honda-tech.com/set1//smile/emcrook.gif
eMpAtHy 05-25-2005 08:16 PM
Re: misshifted... (97Lude)
hrmm, i wonder how many bent valves he has.
john d 05-25-2005 08:34 PM
Re: misshifted... (eMpAtHy)
gl https://honda-tech.com/forums/images/smilies/emthup.gif
DCFIVER 05-26-2005 07:15 AM
damn. http://images.honda-tech.com/set1//smile/emcrook.gif
PirateMcFred 05-26-2005 07:35 AM
What's your setup? Stock H22? If you had stage 2 cams or less and a nice VT upgrade then I might think something other than bent valves...
Pirate
mafia 05-26-2005 08:48 AM
Awww, sucks to be you https://honda-tech.com/forums/images/smilies/emsad.gif gl
darkEN4thgenlude 05-26-2005 05:07 PM
sorry to hear...dat sucks
Monkey Fing a Coconut 05-27-2005 05:44 AM
Re: (darkEN4thgenlude)
ill be the 80th person to say bent valves as well so i can get my post count up 1 too
flyrod 05-27-2005 07:39 AM
Re: (twistedbydezign)
do a compression and/or leakdown test. that will help you determine if valves are bent without taking the head off. It could have been a lot worse though...
RemerLex11 05-27-2005 08:01 AM
Re: (flyrod)
damn i got lucky i did that TWICE and got away with it. http://images.honda-tech.com/set1//smile/emcrook.gif
vwong 05-27-2005 08:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">hrmm, i wonder how many bent valves he has.</TD></TR></TABLE>
I would say all 8 exhaust valves.
I know of at least 2 other Prelude owners and myself who mis-shifted the same way. And all of us had bent all of the exhaust valves. Intake valves were fine though.
RacingLude 05-27-2005 11:57 AM
I wouldn't drive until you know. If the valve is bent, it might break off. Then you'll get to rebuild your bottom end also.
VisPreludeVtec 05-27-2005 12:06 PM
Re: (RacingLude)
i've done this twice, lucky I caught it in time before i screwed it up. Good luck with the rebuild
RemerLex11 05-28-2005 04:57 PM
Re: (VisPreludeVtec)
WTF is that add in your post?? thats bullshit i hope nobody falls for that https://honda-tech.com/forums/images...s/emthdown.gif supercharge your car in 5 min ROFL
eMpAtHy 05-28-2005 05:02 PM
Re: misshifted... (vwong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vwong &raquo;</TD></TR><TR><TD CLASS="quote">I would say all 8 exhaust valves.
I know of at least 2 other Prelude owners and myself who mis-shifted the same way. And all of us had bent all of the exhaust valves. Intake valves were fine though.</TD></TR></TABLE>
lol, there have been pictures of worse than 8 valves..i remember someone on here had 15 valves that bent. :\
DCFIVER 05-28-2005 08:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">do a compression and/or leakdown test. that will help you determine if valves are bent without taking the head off. It could have been a lot worse though...
What am I looking for with a compression test??(it's easiest and the quickest so I'll do that first)
vwong 05-28-2005 09:49 PM
lol, there have been pictures of worse than 8 valves..i remember someone on here had 15 valves that bent. :\</TD></TR></TABLE>
Since I don't frequent this board, I haven't seen the pic. But 15 bent valves? That gotta sucks. https://honda-tech.com/forums/images...s/emsmileo.gif
DCFIVER 06-06-2005 08:51 PM
So I finally got around to compression test. Readings are: 200,190,185,210.
Look ok to me. Does it indicate any problems to any of you. By the way the car IDLES fine and I have no backfiring or missing occuring. Y'all still think it's the valves??
Techna600f4i 06-06-2005 09:38 PM
Damn bro it does sound as if you bet valves,
A compression test will tell you in what or how many cylinders..
ive done that once, got away with a blown Vtec pressure switch!!!
Good luck
Techna600f4i 06-06-2005 09:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">So I finally got around to compression test. Readings are: 200,190,185,210.
185 Is a little low, but now too bad, may have a slightly bent valve,
is your check engine light on?
