MAP. Best location? TB or IM
Old 08-14-2012, 08:13 PM
preludeNApower's Avatar
Default MAP. Best location? TB or IM
Would it be beneficial to run the MAP vacuum line to the TB or IM plenum? Or does this not matter? I know that both technically are in the plenum, but I want to know if being right next the the throttle will affect the readings differently. Thanks for any input. This is on a h22 obd1
Old 08-17-2012, 03:11 AM
holmesnmanny's Avatar
Default Re: MAP. Best location? TB or IM
Stock, it's as close to the butterfly as can be. If I had to guess, I'd say there's a reason for that.
Old 08-17-2012, 05:45 AM
Apex1972's Avatar
I dont think it matters really because some of them are mounted right on the throttle body while others are mounted on a bracket on the firewall.
Old 08-17-2012, 03:58 PM
Even the ones mounted on the firewall have the port on the face of the throttle body.
Old 08-21-2012, 03:37 PM
Beer and Cheese's Avatar
ef9_civic_hatch
10-14-2014 03:29 PM
preludeNApower
08-15-2012 04:14 AM
90_civic_Si
11-28-2009 09:11 AM
Quick Reply: MAP. Best location? TB or IM
